Ignition Switch Wiring +12v
Hey guys,
I'm doing an ignition system upgrade on my 76 Supercab and I'm trying to bypass the resistor wire that comes from the ignition switch to the ignition coil in order to get a full 12v source to a TFI coil. I've been told to look for the pink wire coming from the ignition switch but it looks like there's two of them. Anyone know the wiring schematic for the ignition switch - my goal is to find the wire that draw a 12+ in the "RUN" position.
Thanks
J
Thanks
J
A simple 12 volt bypass circuit is easy to run and leaving your existing wiring alone.
AKA: Don't butcher something you don't need to.
I have a pin-out for 78 illustration for a 78 ign switch but I'll try and find the earlier one.
In the black plastic are letters denoting circuit.
ACC is accessory
I1 or I2 for ignition
ACC is accessory
Thanks - I just figured that splicing out the resistor was the most simple and effective way to get riht amount of current where I wanted it since the wiring is already routed in the harness.
I checked out your gallery, found the ignition pin-out, but I can't make it out too well, it looks a bit blurry to me. Was that the diagram you meant?
FORD STEERING COLUMN WIRING
COLOR APPLICATION
White/Blue R.F. Turn Signal
White/Red Emergency Flasher
Green/White L.F. Turn Signal
Green/Orange L.R. Turn Signal
Green Brake Light Switch
Orange/Blue R.R. Turn Signal/Brake Lite
Blue Turn Signal Flasher
Black/Green Accessory
Black To Fuse Box
Brown/Purple Solenoid
White Or Red/Green To Coil
Gray Hot With Switch On
Yellow Battery 12 Volt
COLOR APPLICATION
Black To Fuse Box
Received 3,102 Likes
on
Marine5811
24
04-23-2018 03:23 PM
Delp73
11-05-2016 07:43 AM
StoneHarding
07-10-2016 11:00 AM
mgerdau
05-28-2016 11:17 PM
pburress
27
11-27-2012 08:13 PM
