EGR Sensor voltage higher than expected
Old 08-25-2007, 10:10 AM
molinsky's Avatar
molinsky
molinsky is offline
My 1994 Ford Explorer has been stalling on idle. My mechanic replaced the hoses to the EGR valve, checked the valve and said it appeared ok. He thought he fixed the problem but it is still happening. I just did a scan and pulled code 336 - EGR sensor voltage higher than expected. Do you think I should replace the sensor?
Old 08-27-2007, 05:14 PM
elmo8641's Avatar
elmo8641
elmo8641 is offline
the sensor will not make it die. your egr valve is prob. getting stuck. that could make your engine die. when it is idling fine disconect the vacuum line to the egr valve. the check engine light will come on, but drive it around to see if it dies. if it don't die then change the egr valve
Old 08-27-2007, 06:25 PM
youngfordguy's Avatar
youngfordguy
youngfordguy is offline
if your egr solinoid is bad wouldn't that affect it to.
Old 08-27-2007, 08:45 PM
elmo8641's Avatar
elmo8641
elmo8641 is offline
the sensor reads what the egr valve is doing. the sensor will not make the engine die. but if your valve is stuck open then to much exhaust is in there, and not enough air. so it will die. the sensor is prob. working right, it is telling you the the valve is open when it shouldn't be (stuck open)
Old 08-27-2007, 08:46 PM
elmo8641's Avatar
elmo8641
elmo8641 is offline
do you understand how the egr system works? if not i will explain it to you. then it would make more sense
Old 08-29-2007, 07:28 PM
molinsky's Avatar
molinsky
molinsky is offline
Elmo, thanks for the replies. I finally took it back to my mechanic and it turned out to be a bad fuel pressure regulator. Seems the spring was sticking and when I stopped produced a too rich condition causing the car to stall. That is probably what also contributed to the sensor to get a high reading.
CraigK
24
01-09-2019 09:32 AM
Thedonk
47
06-22-2016 11:52 AM
Bigjoe31
01-30-2016 06:14 PM
Pad2383
1983 - 2012 Ranger & B-Series
05-11-2013 09:07 AM
SideWinder4.9l
07-30-2011 08:29 PM
Quick Reply: EGR Sensor voltage higher than expected
