Any performance parts for the 4.2L? - Ford Truck Enthusiasts Forums
Old 08-10-2000, 01:05 PM
jparsons97f150 jparsons97f150 is offline
jparsons97f150 is starting off with a positive reputation.
Are there any performance parts for the 4.2? Besides the usual K&N and exhaust which is easy enough to find. Any headers out there?
Old 08-11-2000, 03:59 PM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
Borla and Dynomax each make a cat-back exhaust system, ASP Racing makes underdrive pulleys, and Wynjammer makes superchargers. Also, check out www.summitracing.com
Ken Payne
Ford Truck Enthusiasts Admin
[img src="/clipart/logosmall.gif"]
(Click on Profile/Signature to add your own custom signature)
Old 12-03-2000, 03:09 PM
lilpuu lilpuu is offline
lilpuu is starting off with a positive reputation.
Could you tell me more about the Wynjammer SC.
Where can I contact them. I heard that no one made a SC for this Engine.
Old 07-04-2001, 09:29 AM
EHanson EHanson is offline
EHanson is starting off with a positive reputation.
Hi, I recently bought a 2000 F150 with 14000 on it. I find the power to be plentiful. I just got rid of a 1994 Ranger with 98 HP.
I found a site that will have just about everything you will need to gain up to 80 HP more out of you 4.2L.
I plan on boosting my HP up a little once my warrentee is up.
Erick
Old 08-30-2001, 08:46 AM
KPO KPO is offline
KPO is starting off with a positive reputation.
The 3.8L and the 4.2L are both 90 degree V blocks with the same deck height and bore spacing. This means that even though the heads and intake manifolds are different they will interchange. The following info is a copy from a previous post I responded to that might be of some interest.
Don't know if anyone is still watching this string but there is something all 4.2L V6 owners should now. The 4.2L is a bored and stroked brother to the 3.8L found in Windstars, Mustangs and the old Thunderbird Supercoupe. I have researched this because I was trying to make a 4.2L supercharged engine out of 3.8L parts and stick it in a Mustang.
This project never evolved for me but I discovered that the cam, upper intake, supercharger and heads from a 3.8L Supercoupe engine will fit on a 4.2L engine. Most of these parts are still available over the dealer's parts counter but I would find a total Supercoupe T-Bird if possible. I never researched this swap for a F-150 but the first real issues you will come across is getting the FEAD system to operate correctly. The FEAD system on the 4.2L must extend about 7 inches forward of the engine block and the 3.8L Supercoupe's FEAD is very tight and close to the block so this will be an issues to over come. FEAD = Front End Accessory Drive
Old 08-30-2001, 12:55 PM
kjsharrer kjsharrer is offline
kjsharrer is starting off with a positive reputation.
I added a gibson super truck exhaust and poweraide throttle body extension. The are both simple to install mine took me a hour at the most. Im looking to install a diablo chip next, it will install in the cpu without the tape that superchip needs to hold it in. Thats if I can find my oil leak.
Old 09-10-2001, 11:29 AM
OffRoad OffRoad is offline
OffRoad is starting off with a positive reputation.
1-JBA Headers $331.95
Adds 15-20 HP
20-30' LBS torque
10% mpg improvement
2-Volant Ram air $207.95
adds 15-20 Hp
20-30' lbs torque
10% mpg imp
3-Gibson Singleside Exhaust $289.95
adds 15-20 hp
20-30' lbs torque
10% mpg imp
4- Hypertech Programmer $339.95
30 HP
5- TBI Riser Plate $91.95
7-10 hp
up to 10% mpg imp
www.performancecombos.com
Old 09-12-2001, 01:26 PM
Hi Thanks for the info. On that throttle body you mentioned for the 4.2 F-150. How much power did you notice? I installed a Gibson muffler system and a chip. Is the throttle body worth the money? Supercharger would be nice but not if I have to research a lot.
Andy
Old 01-08-2003, 04:31 AM
bpassmore bpassmore is offline
bpassmore is starting off with a positive reputation.
Are these still the reccomended perf options now?
the ASP pulleys - do they really help at all?
and the cat-backs - any good gains?
Old 01-09-2003, 08:52 AM
HPfreak HPfreak is offline
HPfreak is starting off with a positive reputation.
The throttle body to me is not worth the money. The throttle body is a couple hundred dollars but you can polish and port your throttle body to achieve the same amount of power as a bigger throttle body. $0.02
Old 01-11-2003, 05:34 PM
skoop skoop is offline
skoop is starting off with a positive reputation.
What are the differences between 4.2" vs. 8" display in XLT Instrument cluster? babybober 2017 Super Duty 1 11-23-2016 10:21 AM
2000 f150 4.2 engine removal madtama 3.8 & 4.2L V6 1 04-18-2016 10:12 AM
Jet Chip on 4.2L archeat2 3.8 & 4.2L V6 6 08-28-2006 10:51 AM
The 4.2ltr V6 Performance.... Sheldontoxicman 3.8 & 4.2L V6 9 01-05-2003 08:33 PM
4.2 oil test result -vs- short life expectancy..comments?? BrianA 3.8 & 4.2L V6 6 09-14-2002 03:07 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
00, 01, 2000, 42, 42l, back, cat, dynomax, f150, ford, hp, improvement, parts, performance, pulleys, system, underdrive
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
