highest mileage on 4.2 ?? - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 07-16-2008, 07:35 PM
fire240's Avatar
fire240 fire240 is offline
fire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputation
I have an 03 with 60,200 miles on it. Only problem I have had was a bad alternator at 50,000 miles.
  #62
Old 07-19-2008, 10:06 PM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.
Pretty impressvie TK!
Currently I have 146,000 on my '05.
Oil change every 5K with whatever 5W20 is on sale.
Autotransmission fluid change every 30K or so.
Still no problems of any sort since front brake rotors 100K miles ago and rear axle seal 30K miles ago.
  #63
Old 07-29-2008, 11:09 PM
higgins81 higgins81 is offline
higgins81 is starting off with a positive reputation.
I have a '98 w/ 154000
  #64
Old 08-02-2008, 01:46 PM
Drizzt's Avatar
Drizzt Drizzt is offline
Drizzt is gaining momentum as a positive member of FTE.
engine still runs great and im at 265,000 on my 99
  #65
Old 08-19-2008, 11:26 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150 Milwaukee1979F150 is offline
Milwaukee1979F150 is gaining momentum as a positive member of FTE.
I don't own 4.2L
I went to junkyard saw 1999 E250 with v6 4.2L it is original engine. I check dashboard it have over 340,000 miles so I say wow that imposes if it never replace engine so I check oil. It look good but it seem someone keep engine look clean no oil drip.
It was Fleet by SBC telephone. That van look bad shape due rust but engine look clean.
  #66
Old 09-08-2008, 07:25 PM
Xrider Xrider is offline
Xrider is starting off with a positive reputation.
01 e250 with supposedly original engine and 370K miles. its got all kinds of problems but it runs. I even towed a 2700lb boat, hah...
leaks all over the place but im trying to keep it alive
  #67
Old 10-29-2008, 12:19 AM
terrmat terrmat is offline
terrmat is starting off with a positive reputation.
mines great so far ive had older ford s with the 300 six in them man were they indestructible!! but as for the 4.2 it runs great , mine has 92000 on it and it runs like a champ!!
  #68
Old 11-02-2008, 12:15 PM
mustangman02232's Avatar
mustangman02232 mustangman02232 is offline
mustangman02232 is starting off with a positive reputation.
i dont own a 4.2 yet (looking to swap one into my mustang as they are both essex motors and the 4.2 just has a longer stroke) ive got 90k on mine and beat it like no tomorrow at the track and it doesnt leak or anything, ive seen a 3.8 with 450k on it and still running the original belt and battery, basic maintence will go a long way
  #69
Old 11-02-2008, 04:39 PM
Shadow351's Avatar
Shadow351 Shadow351 is offline
Shadow351 is starting off with a positive reputation.
I've got a 97 F150 with the 4.2L, it got 170000mi on it runs great but has a t-case issue. Just threw a cms code last week but i've had it since 155,000 and havn't touched the engine, wich i pretty sure is the original.
http://www.angelfire.com/electronic2/carluvr/
  #70
Old 11-06-2008, 10:22 PM
pitviper1996 pitviper1996 is offline
pitviper1996 is starting off with a positive reputation.
Figured i'd post even though it has no substance to anyone else lol. I have an 05' ford f-150 4.2l 5 -speed with 11,xxx on it no problems even though its not even broke in yet and its almost 4 years old!
  #71
Old 11-14-2008, 10:48 PM
rreynold rreynold is offline
rreynold is starting off with a positive reputation.
High Mileage
Have an '01 F150 4.2 with 123,000 miles. I recently noticed a little puff of white smoke at startup on cool mornings. Knowing the history of 4.2s to have intake gasket problems, I decided to have the local dealer replace the gasket, simply because the gasket replacement was fairly inexpensive (about $265) and if it WAS going bad, I would regret saving the $265 and paying for an engine. No more smoke and it actually seems to be a little peppier, Probably from just cleaning things up as part of the job. Other than the gasket, I've replaced the throw out bearing/slave and the alternator, that's it. It runs great and drives great, much better than my old twin I-beam Ranger although the Rangers 4.0 seemed to have a little more low end grunt. All in all, a good truck.
  #72
Old 11-19-2008, 08:56 PM
97_blue_oval 97_blue_oval is offline
97_blue_oval is starting off with a positive reputation.
Newbie here and like what I see. I have a 97 F150 I bought in 96. The truck has 400k plus but I changed out the first engine at 245k since I drive long distances around Tx. This engine has about 200k but the odometer quit working about 6 months ago showing right at 400k. I drive about 3k to 3.5k a month. It's been a great truck.
  #73
Old 11-20-2008, 12:02 AM
BrianA's Avatar
Welcome and hope you enjoy FTE and the 3.8/4.2 forum.
While I'm at it, 155,000 on my '05 with no problems.
  #74
Old 12-13-2008, 11:17 PM
horizonhuskies horizonhuskies is offline
horizonhuskies is starting off with a positive reputation.
117,500ish miles.
Hey brian. Long time.
  #75
Old 02-08-2009, 06:40 PM
93RangerXL4x2's Avatar
93RangerXL4x2 93RangerXL4x2 is offline
93RangerXL4x2 is starting off with a positive reputation.
307,943kms on mine, my uncles got 330,000kms on his, its a 97 mines a 99
Australian f250 2001 with 4.2 turbo Diesel Timf350 General Diesel Discussion 4 12-22-2010 03:29 PM
97 f150 4.2l worth rebuilding? or replacing? murfsup 1997 - 2003 F150 1 01-30-2010 09:06 PM
97 4r70w swap brianb07 1997 - 2003 F150 3 12-18-2008 09:49 PM
2001 4.2 in 98 F150? blue67stang 1997 - 2003 F150 2 01-06-2007 06:44 PM
4.2 missing?? fromme87 3.8 & 4.2L V6 4 02-14-2006 07:24 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1997, 1998, 42, chain, engine, f150, find, ford, intake, leak, problems, serpentine, timing, troubleshooting, trucks, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
