highest mileage on 4.2 ?? - Page 2 - Ford Truck Enthusiasts Forums
Old 12-26-2002, 06:33 PM
tiger2 tiger2 is offline
tiger2 is starting off with a positive reputation.
I HAVE A 98 F150 WITH 4.2 IT HAS 104.000 THE ONLY TROUBLES i have had. IT START TO MISS REALLY BAD CHANGED PLUGS AND WIRES AND IT`S RUN FINE .BUT AFTER READ THIS FROUM. I going to trade this summer anybody know of any troubles with 4.6 liter v8
Old 12-26-2002, 07:07 PM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.
>Still checking in.......I'm around 64,000 now and so far so
>good!!
>Brian A
Now at 81,000...still zero problems.
Brian A
Old 12-30-2002, 08:12 PM
BlacKMaGic BlacKMaGic is offline
BlacKMaGic is starting off with a positive reputation.
i have a buddy who has a 97 F150 4x4 reg cab. this truck has just turned 250k w/no major engine trouble since he has had it(he bought at 204k) he owns a lawnservice and has worked this truck extremely hard. put a snowplow on it last winter. so it has plowed snow for 2 winters and pulled his lawn equipment trailer for 3yrs. he has hauled mulch that was probably loaded 1000 lbs over the trucks GVW without a hitch.
so far the only thing he has had to replace were all the tierods.
i am a dodge guy at heart but this truck was definetly "built ford tough". i would have no problem using this thing anytime for anything.
just one good damn truck.
Old 12-31-2002, 01:12 PM
FRANKFRANKIE FRANKFRANKIE is offline
FRANKFRANKIE is starting off with a positive reputation.
[updated:LAST EDITED ON 31-Dec-02 AT 01:13 PM (EST)]Just turned 373,000 and still going back and forth to KC everyday. I think I might have a injector going out. But who cares this truck is awsome!!!!!!!
Old 01-08-2003, 06:17 PM
Lee2002 Lee2002 is offline
Lee2002 is starting off with a positive reputation.
I have a 1997 f150 xlt 4.2. It has 147,000 miles on it. Sometimes in the mornings on a cold morning it ticks and then when warmed up it stops. I live in Texas and we have very few cold mornings. She runs like a champ still! Theres no use in worring about these trucks, the way i look at it, if it's gonna break worring wont help it. Dont fix something that's not broke. Just my 2 cent's. I also have a 1986 f150 truck and it has 309,879 on it, it's got a small light knock at the bottom of the motor that started over 100,000 miles ago, it still runs like a champ.
Old 01-13-2003, 08:21 PM
pos ford pos ford is offline
pos ford is starting off with a positive reputation.
Bought mine new in 2000, at 40k the starter went $150.00. Now at
45k motor ticking/rattling.
Old 01-13-2003, 09:09 PM
Old 04-11-2003, 03:22 PM
ford4sure ford4sure is offline
ford4sure is starting off with a positive reputation.
I've got a 97 F150 with 129000 miles and still running strong, no major reapirs. Just keep the oil changed.
Old 04-14-2003, 12:16 PM
PSDChick PSDChick is offline
PSDChick is starting off with a positive reputation.
Smile highest mileage on 4.2 ??
My 2000 has 63,000 on it now! I only just now got a "ticking" sound coming from it.
Old 04-19-2003, 04:48 AM
srgrande15 srgrande15 is offline
srgrande15 is starting off with a positive reputation.
ok so ya'll seem to talk about the oil changes a lot in here. my factory book says use 5w20 every 5000 miles. this seemed a little much for me but i followed it anyway. ive now got over 44k on my 01 4.2L and it does great. i do live in texas though and most of my miles are on these great and oh so long highways. could someone gimme the heads up on the type of oil and frequency of change? thanks a bunch.
Old 04-19-2003, 07:47 AM
BrianA's Avatar
Welcome to FTE!
Check the Oil and Lube forum. You find out more than you ever wanted to know about oil - there are some pretty good discussions and pretty smart guys.
Seems the general opinion is Ford says 5w20 so they get the CAFE benefit. Nothing wrong with using 5w20, but I'm guessing you don't have to.
I'm at 91,000 miles (2000 model), I've always used 10W30.
5,000 mile intervals is fine (it's what I use).
Old 04-23-2003, 02:15 PM
yomamaha yomamaha is offline
yomamaha is starting off with a positive reputation.
bought mine new in 99, and with the exception of a warranteed fuel pump, it has always started and run well. i have 88xxx on it now and am getting increasingly better milage (21 mpg now), and it seems strong yet (i think good and broke in now). a little lifter noise at startup, but i'm not complaining about the engine one bit. try to change oil every 4-5000, have been running valvoline duralube (5w-30 winter, 10w-30 summer, Minnesota cold!) since 20k. it's a strong enough motor for pulling (3.55's help), but the REST of the drivetrain leaves much to be desired!
  #28
Old 05-01-2003, 07:45 PM
fuser fuser is offline
fuser is starting off with a positive reputation.
Bought my 98 F150 SC 4.2L 2WD 5-SP new in August of 1998. Not the highest mileage but my truck now has 73,000 miles. I have kept track of gas mileage since new and have averaged 19.7 mpg. I have had zero problems with this engine, in fact my first major service for the truck other than regular oil changes, was lower ball joints and disc brake pads done last week. My first real problem is a vibration when applying the brakes which I've been told is probably the rear brakes.
The 4.2L is perfect for my use; plenty of power and great gas mileage for a full size truck.
  #29
Old 05-28-2003, 02:12 PM
20004x4 20004x4 is offline
20004x4 is starting off with a positive reputation.
Well i have 92000 on my 1998 E150 4.2 . Had an alternator go bad , power steering pump, and carbon buildup in the upper intake egr ports that caused a shudder under hard acceleration, and brake rotors replaced. So knock on wood its still kicking.
  #30
Old 06-04-2003, 01:39 PM
97 Bentley 97 Bentley is offline
97 Bentley is starting off with a positive reputation.
My 97 F150 is just getting ready to roll over 188,000 miles. No real problems as of yet but the tranny has a shudder in it so will run it until it lets go. Getting ready to replace the exhaust because of it running rough. The cats are bad so replacing it all the way back. Pretty good truck so far.
Question about TPMS BigBri BigBri 6.7L Power Stroke Diesel 14 12-27-2010 11:08 AM
2001 4.2 in 98 F150? blue67stang 1997 - 2003 F150 2 01-06-2007 06:44 PM
My new toy!! 4.2manster 3.8 & 4.2L V6 5 02-08-2005 10:24 AM
4.2 oil test result -vs- short life expectancy..comments?? BrianA 3.8 & 4.2L V6 6 09-14-2002 03:07 PM
input wanted...chip for 4.2L V6 qwpo Computer Chips & Tuners 4 09-04-2001 10:27 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1997, 1998, 42, chain, engine, f150, find, ford, intake, leak, problems, serpentine, timing, troubleshooting, trucks, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
