highest mileage on 4.2 ?? - Page 14 - Ford Truck Enthusiasts Forums
  #196
Old 01-03-2014, 02:59 AM
HankMurphy HankMurphy is offline
HankMurphy is starting off with a positive reputation.
Only 116 thousand miles on my 2008. Got to get out more.
Only major maintenance so far has been brakes.
  #197
Old 01-03-2014, 07:32 AM
offroadnt's Avatar
offroadnt offroadnt is offline
offroadnt is starting off with a positive reputation.
498654km (309849 miles), just retired her to on farm use and upgraded to a 2010 F250, a truck that's more suited to the job.
  #198
Old 03-09-2014, 08:47 AM
PJ Riggs PJ Riggs is offline
PJ Riggs is starting off with a positive reputation.
I have a 2000 F-150 4.2L w a 5 speed with 220,000 miles with everything factory except spark plugs & wires
  #199
Old 03-14-2014, 01:44 PM
willy j willy j is offline
willy j is starting off with a positive reputation.
178,000 2000 f1504.2 v6
just found a puddle of anti freeze setting on my block underneath the intake, any ideas
  #200
Old 04-02-2014, 09:45 PM
sparkyjj sparkyjj is offline
sparkyjj is starting off with a positive reputation.
WILL NEVER DIE!!
'03 E-150 with 389,xxx on it. Use to be a fleet van and I have had it for 2 or 3 years had to put alternator battery tires gas and change oil otherwise still goin strong. Never has been opened up and had major work done. Use it for my daily driver it gets 17 to 23 mpg average and still pull a trailer full of scrap iron with it. Expect to hit 400,000 by end of summer. My friend drove it daily for his job and we TRIED to blow it up cuz he wanted the company to get him a new one. Nothing like throwing the trans into 2nd at 50+ mph and holding your foot to the floor. No problems with anything on van, all original nothing has been opened up engine, trans rear end, ect.
  #201
Old 04-14-2014, 06:12 PM
XSleeper XSleeper is offline
XSleeper is starting off with a positive reputation.
02 F150 4.2L 5 speed manual... 261,000 and counting.
Recently replaced 02 sensors, cleaned fuel injectors, intake plenum gaskets, valve cover gaskets, throttle gasket, pcv valve and isolator bolts to cure a vacuum leak and now it purrs like a kitten again.
  #202
Old 05-08-2014, 09:16 AM
alpha7mm alpha7mm is offline
alpha7mm is starting off with a positive reputation.
I have 154,000 miles and mines runs quiet when I start it up it has rough idle
  #203
Old 05-28-2014, 11:02 PM
gsmarcano gsmarcano is offline
gsmarcano is starting off with a positive reputation.
I have a 2000, with about 235,000 on the clock and still going strong. But I've always used Mobil one and taken it relatively easy on the old big Blue, as my wife and I like to call it.
  #204
Old 08-04-2015, 10:41 AM
wam92285 wam92285 is offline
wam92285 is starting off with a positive reputation.
highest mileage
Quote:
Originally Posted by BrianA View Post
Thanks for the reply...whatever everyone else's experiences, I'm just gonna keep driving and see how long it will go.
Brian
my 4.2 has 342000 on original motor
  #205
Old 08-09-2015, 02:43 PM
Ramiro Saldaña Jr. Ramiro Saldaña Jr. is offline
Ramiro Saldaña Jr. is starting off with a positive reputation.
High mileage but runs great!!
Quote:
Originally Posted by LK View Post
Since nobody else responded to your post, here are the only two higher-mileage 4.2L trucks I'm aware of: a '97 with 135,000 miles, and a '98 with 125,000 miles (both are on their original engine). Those are the only two I'm aware of with over 100K...it seems like the 4.2L isn't all that common.
LK
I got a 99' xlt and just went over 270K. Still runs awesome only problem ever had was I replaced the oil pan gasket.
  #206
Old 09-30-2015, 09:11 PM
252,000 and change.
  #207
Old 11-18-2015, 03:06 PM
Pgh Rebel's Avatar
Pgh Rebel Pgh Rebel is offline
Pgh Rebel is gaining momentum as a positive member of FTE.Pgh Rebel is gaining momentum as a positive member of FTE.
Got a 2006 here that I ordered because I wanted the 5-speed. Also got the 8' bed, 3.55 limited slip and the towing package. That netted me the heaviest duty 5-speed that Ford would build in that year. 'Course it is 2wd since they no longer offered the 4.2 with 4x4. Anyway got 105,000 on it now and runs like a champ! I fully expect to keep it for another 10 years or more and see 200k at least before retiring it from daily use. The rust hasn't gotten to the body at all, just the bumpers and the steel wheels. I treated that with Rustoleum before it got too bad and that stopped the rust.
  #208
Old 11-19-2015, 01:02 PM
BlueOvalFitter's Avatar
BlueOvalFitter BlueOvalFitter is offline
BlueOvalFitter is gaining momentum as a positive member of FTE.
Quote:
Did you change the gasket yourself? I thought the pan gasket on the 4.2 was 2 half moon seals for each end of the pan and a bead of silicone for the rest.
  #209
Old 01-17-2016, 07:15 PM
fordmudtruck27 fordmudtruck27 is offline
fordmudtruck27 is starting off with a positive reputation.
My 1998 4.2 f150 automatic 2wd has 289,500 miles still running strong no problems original motor and only had rear main seal done to it from my friend i got it from towed 8000lbs skid steerers with it and put 2700lbs in bed best 450 bucks ever spent it needed a rear
  #210
Old 07-15-2016, 06:13 PM
Patriotgrunt Patriotgrunt is offline
Patriotgrunt is starting off with a positive reputation.
Just picked up an 03 with 117K. I'm stoked about this truck. It's going to be a great truck.
Australian f250 2001 with 4.2 turbo Diesel Timf350 General Diesel Discussion 11 03-16-2017 02:29 AM
2000 f150 4.2 engine removal madtama 3.8 & 4.2L V6 1 04-18-2016 09:12 AM
2001 4.2 in 98 F150? blue67stang 1997 - 2003 F150 2 01-06-2007 05:44 PM
redline ??? qwpo 3.8 & 4.2L V6 15 08-27-2004 12:36 PM
4.2 swap bobsands 3.8 & 4.2L V6 1 08-05-2002 10:53 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1997, 1998, 42, chain, engine, f150, find, ford, intake, leak, problems, serpentine, timing, troubleshooting, trucks, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
