Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-24-2007, 01:59 PM
fordmtnman's Avatar
fordmtnman fordmtnman is offline
Garage is empty, add now
fordmtnman is starting off with a positive reputation.
Your mileage may vary
What model ford pickup do you drive and what are you getting for fuel economy?
07 F150, V6 5 spd, Reg Cab Shortbed; 20.6 mpg over the 5 tanks of gas I've put through it.
__________________
2007 Ford F150 XL 2WD
4.2L V6, 5spd, 3.55:1
Average MPG: 20.6
aiming for 25 mpg
  #2 (permalink)
Old 08-25-2007, 12:14 PM
76supercab2's Avatar
76supercab2 76supercab2 is offline
76supercab2 has a good reputation on FTE.76supercab2 has a good reputation on FTE.76supercab2 has a good reputation on FTE.
1976 F-150 Supercab 390 V-8 4bbl carb auto trans 13mpg hwy.
  #3 (permalink)
Old 08-26-2007, 12:37 PM
thor1721 thor1721 is offline
thor1721 is starting off with a positive reputation.
2007 f-250 6speed tranny 5.4l engine 4:10 gears empty on highway 13mpg
  #4 (permalink)
Old 08-27-2007, 09:40 AM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
The 1994 F-150 4x4, 5.0, E4OD, 3.55, stock tire size,
average over several years, 11/15 a lot less than the EPA 15/18 "estimate".
Jim
  #5 (permalink)
Old 08-27-2007, 12:01 PM
I find it humorous that much newer trucks with smaller engines, more emissions crap, computer control and more gears cannot significantly outperform (or outperform at all) my 31 year old truck in the efficiency arena.
  #6 (permalink)
Old 08-27-2007, 01:03 PM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
The "emission crap" doesn't exactly help efficiency, to say the least. If they were optimized for efficiency, they could probably get lot better mpg. Also, todays cars and trucks have a lots of not really necessary equipment like power windows, power and heated seats, etc.
It's not a pickup truck, but my '95 Bronco with 351W can get 17+ mpg on a highway.
  #7 (permalink)
Old 08-27-2007, 03:10 PM
I think you'll find that it's more a function of the amount of work the truck can do, and how fast it can get the job done (POWER). To perform a certain job at a specific rate requires X amount of power. Requires the same amount of power regardless of the truck on the other end of the hitch. And to produce that amount of power simply requres that amount of fuel. IOW, it's a limitation of physics and not some evil oil company/automaker conspiracy.
  #8 (permalink)
Old 08-27-2007, 05:09 PM
fordmtnman's Avatar
Quote:
Power is not a function of how much fuel you cram into an engine per se. A more effecient engine will make the same power with less fuel. And a truck with lower gears and less power may well be able to out work a more powerful truck with higher gears. Sorta depends on the work involved too. If that work is blowing down the interstate at 90 mph hauling cattle or horses, then you're gonna need horsepower, no doubt. For pulling stumps, I'd take the family's 40hp farmall tractor...
In any case, when it comes to towing or 4 wheeling, I'd rather have less power and the gear reduction I need, than have gobs of power, but less gear reduction. (or less gear choices) I think that the less powerful the engine is, the more gears they should put in the transmission.
__________________
Average MPG: 20.6
aiming for 25 mpg
  #9 (permalink)
Old 08-27-2007, 08:05 PM
Not sure why you brought up the conspiracy idea since oil companies/automakers just follow (they have to) the rules set forth by the fed. Having said that, the tightening of emission and crash safety rules (weight) had a negative impact on mpg. The late 80's Honda Civic CRX HF had an EPA rating of 50/56 (!!) mpg, for example.
On a personal note, my '71 Maverick with a 200 CID I6 and 3 speed stick could get 26 - 27 mpg on a highway (ethanol free gasoline and 55 mph speed limit at that time) when a '77 Pinto with a significantly smaller I4 and 4 speed could only get 24 - 25 mpg, at best. (E10, 70 mph speed limit)
  #10 (permalink)
Old 08-28-2007, 12:35 PM
The problem is WEIGHT. The equation f=ma means that it takes more force (horsepower) to accelerate more mass (weight). All the powertrain efficiency gained in the last decade or so has been wasted on bloat. The average 2007 F-series, Ram, Sierra, Silverado, etc. is about 1000lb heavier unladen (EMPTY) than average 1997 models. It looks even worse if you go back to the mid-20th century. Early 1960's F-250's tipped the scales about the same as that 1997 F-150.
Dont blame it on emissions controls now. Lean-burning EFI, high energy direct ignition with optomized timing curves, overhead cams, multi-valve heads, higher compression ratios, overdrive gears all increase efficiency. It was the 1970's stuff that was bad, pre-computer, vacuum hose hell, when they really didnt know what they were doing.
Jim
  #11 (permalink)
Old 08-28-2007, 12:52 PM
Quote:
*Looks at post #2 and compares to post #3*
ORLY?
  #12 (permalink)
Old 08-28-2007, 02:48 PM
One word: EGR, just to name one.
On a more detailed note, because of NOx issues, the peak temperature need to be controlled, and I believe, the mixture isn't as lean as it could be for peak efficiency.
  #13 (permalink)
Old 08-29-2007, 09:17 AM
Modern EFI systems are calibrated to run lean-of-peak most of the time. This reduces temperatures, and NOx, by itself. Reduction cats take care of the rest. EGR is not needed on all engines because of this.
Jim
  #14 (permalink)
Old 08-29-2007, 09:27 AM
badass truck badass truck is offline
badass truck is starting off with a positive reputation.
my first vehicle was a 1994 f150 and it gets about 18mpg on the highway and about 14 or 15 in town. thats driving it really nice. just cruisin not runnin stop light to stop light. i have the k&N fuel injection performance kit and a throttle body spacer on it thought along with 161,000 thousand miles lol
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
