Competition Diesel racing, sleds, dynos, power tuning and max performance.
Rear axle strength for sled pulling...
Old 08-24-2007, 01:18 PM
armikk's Avatar
armikk
armikk is offline
I was running a rear 70HD on my pulling truck. At my last pull, right before the 300' mark, I ended up twisting off the pinion gear right at the end of the yoke. I'm planning to upgrade and thinking about a Dana 80. I've located an 80 out of an E350 with 35 spline 1.5" diameter axle shafts. Are any of you guys breaking gears or shafts on the Dana 80's with 35 spline (1.5" shafts) or 37 spline (1.6" shafts)? Is anyone running upgraded / aftermarket shafts in their 80? -thanks-
Old 08-24-2007, 03:09 PM
blake 7.3L's Avatar
blake 7.3L
blake 7.3L is offline
I dont know about the 80 but a good friend of mine had the same problem with his 70. Except his put a hole in the bottom of the axle casing the size of my fist.
Old 08-24-2007, 03:44 PM
armikk's Avatar
armikk
armikk is offline
Yea, at least my housing was still useable. Just took out the gears and gouged up the bearings.
Are the guys without rear end problems running Sterling 10.5's, Dana 80's or something else? Open, welded, limited slips, or lockers? -thanks-
Old 12-30-2007, 09:47 AM
bogginf350's Avatar
bogginf350
bogginf350 is offline
Dana 80 is the way to go... Cheaper route is a gm 14 bolt.
Old 12-30-2007, 08:52 PM
duramaximizer's Avatar
duramaximizer
duramaximizer is offline
The problem one of my friends had with a stock Dana 80 was twisting the axils out of it. Aftermarket axil seem to have solved the problem for now. GM 14 bolt is super strong also.
Old 03-05-2008, 08:51 AM
scottie2hottie's Avatar
scottie2hottie
scottie2hottie is offline
14 bolt axles aren't as strong as an 80 but the 80 has a weak pinion yoke in comparison IMO. Seen two of those break off, one damaging the pinion gear, never seen a 14 bolt break a pinion yoke. Never seen a sterling break the gears...axles though will break. I personally would rather break a shaft than anything else in there, but ideally of course would like to break nothing. Could always upgrade to militarys
Old 05-18-2010, 08:57 PM
8925093ranger's Avatar
8925093ranger
8925093ranger is offline
stock 35 spline 80 will befine know many poeple i pull with running them behind big torque cummings and one 900 ft lbs 6.0
Old 05-19-2010, 08:35 AM
Gus Erickson's Avatar
Gus Erickson
Gus Erickson is offline
I run a 14 bolt in my stock pulling truck. Never have had a problem. It was in the truck when I got it. The PO said he was breaking 70s all the time. 14bolts have gotten so cheap around here[200 to 300 bucks] they just seem a good option.
Old 05-19-2010, 08:53 PM
06silvercrew's Avatar
06silvercrew
06silvercrew is offline
Sterling 10.5 with stock ford limited slip and stock shafts. Welded axle tubes. So far so good.
robbs64
04-01-2017 08:15 PM
sdunham
2017+ Super Duty
16
11-16-2016 01:44 PM
joe_jeep
09-28-2008 08:46 PM
65'f1004x4conver
03-04-2007 12:26 AM
Steve_Uzi
02-25-2002 06:58 AM
Quick Reply: Rear axle strength for sled pulling...
