Go Back   Ford Truck Enthusiasts Forums > Diesel > Competition
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Competition Diesel racing, sleds, dynos, power tuning and max performance.
  #1 (permalink)
Old 08-24-2007, 01:18 PM
armikk armikk is offline
Garage is empty, add now
armikk is starting off with a positive reputation.
Rear axle strength for sled pulling...
I was running a rear 70HD on my pulling truck. At my last pull, right before the 300' mark, I ended up twisting off the pinion gear right at the end of the yoke. I'm planning to upgrade and thinking about a Dana 80. I've located an 80 out of an E350 with 35 spline 1.5" diameter axle shafts. Are any of you guys breaking gears or shafts on the Dana 80's with 35 spline (1.5" shafts) or 37 spline (1.6" shafts)? Is anyone running upgraded / aftermarket shafts in their 80? -thanks-
  #2 (permalink)
Old 08-24-2007, 03:09 PM
blake 7.3L's Avatar
blake 7.3L blake 7.3L is offline
blake 7.3L is starting off with a positive reputation.
I dont know about the 80 but a good friend of mine had the same problem with his 70. Except his put a hole in the bottom of the axle casing the size of my fist.
__________________
1997 F350 CREWCAB 4x4 7.3L Powerstroke, 4.10's, Built BTS Auto, 6 pos. chip with Cale's Tunes, 4" exhaust, Z-Series Gauges, 140V IDM, Tymar Intake, HPX, Adrinaline HPOP, 7.3L intercooler, RDS stage 2's (180cc), Modded H2E, and 3" SD intakes
Coming Soon: Locker and Elec. Fuel
  #3 (permalink)
Old 08-24-2007, 03:44 PM
Yea, at least my housing was still useable. Just took out the gears and gouged up the bearings.
Are the guys without rear end problems running Sterling 10.5's, Dana 80's or something else? Open, welded, limited slips, or lockers? -thanks-
  #4 (permalink)
Old 12-30-2007, 09:47 AM
bogginf350's Avatar
bogginf350 bogginf350 is offline
bogginf350 is new and has a neutral reputation at this point.
Dana 80 is the way to go... Cheaper route is a gm 14 bolt.
__________________
Josh Davis, FTE resident injector builder.
03 f350 srw 4x4 6.0..
94 f1504x4 shortbox 523ci A heads
79 f1504x4 shortbox 547ci Blue thunders...
  #5 (permalink)
Old 12-30-2007, 08:52 PM
duramaximizer duramaximizer is offline
duramaximizer is new and has a neutral reputation at this point.
The problem one of my friends had with a stock Dana 80 was twisting the axils out of it. Aftermarket axil seem to have solved the problem for now. GM 14 bolt is super strong also.
  #6 (permalink)
Old 03-05-2008, 08:51 AM
scottie2hottie's Avatar
scottie2hottie scottie2hottie is offline
scottie2hottie is gaining momentum as a positive member of FTE.
14 bolt axles aren't as strong as an 80 but the 80 has a weak pinion yoke in comparison IMO. Seen two of those break off, one damaging the pinion gear, never seen a 14 bolt break a pinion yoke. Never seen a sterling break the gears...axles though will break. I personally would rather break a shaft than anything else in there, but ideally of course would like to break nothing. Could always upgrade to militarys
__________________
2002 F350 "Big White"
2001 F150 "Black Pearl"
1996 F350 "Red Sled"
Proud to be an OHIO BOY
  #7 (permalink)
Old 05-18-2010, 08:57 PM
8925093ranger 8925093ranger is offline
8925093ranger is starting off with a positive reputation.
stock 35 spline 80 will befine know many poeple i pull with running them behind big torque cummings and one 900 ft lbs 6.0
  #8 (permalink)
Old 05-19-2010, 08:35 AM
Gus Erickson's Avatar
Gus Erickson Gus Erickson is offline
Gus Erickson is starting off with a positive reputation.
I run a 14 bolt in my stock pulling truck. Never have had a problem. It was in the truck when I got it. The PO said he was breaking 70s all the time. 14bolts have gotten so cheap around here[200 to 300 bucks] they just seem a good option.
  #9 (permalink)
Old 05-19-2010, 08:53 PM
06silvercrew's Avatar
06silvercrew 06silvercrew is offline
06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.
Sterling 10.5 with stock ford limited slip and stock shafts. Welded axle tubes. So far so good.
__________________
-Scott
SOLD 2-28-11.....
'06 F250 CC/SB PSD. 2'' lift, Bilstein 5100's, Dual stabilizers, 20'' Harley wheels, 35-12.50 MT ATZ's, 08 Mirrors, ARP studs, EGR delete, 4'' MBRP, X3 with custom tunes, Full gauges, scangauge II, Coolant filter, Red top Optimas, DC 185a alt,
Tags
1996, 73l, axil, axle, breaks, builder, comparison, dual, f350, ford, pulling, rear, rearend, sled, strength, truck, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
