Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Competition
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Competition Diesel racing, sleds, dynos, power tuning and max performance.
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 08-24-2007, 01:18 PM
armikk is starting off with a positive reputation.
Rear axle strength for sled pulling...
I was running a rear 70HD on my pulling truck. At my last pull, right before the 300' mark, I ended up twisting off the pinion gear right at the end of the yoke. I'm planning to upgrade and thinking about a Dana 80. I've located an 80 out of an E350 with 35 spline 1.5" diameter axle shafts. Are any of you guys breaking gears or shafts on the Dana 80's with 35 spline (1.5" shafts) or 37 spline (1.6" shafts)? Is anyone running upgraded / aftermarket shafts in their 80? -thanks-
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 08-24-2007, 03:09 PM
blake 7.3L is starting off with a positive reputation.
I dont know about the 80 but a good friend of mine had the same problem with his 70. Except his put a hole in the bottom of the axle casing the size of my fist.
__________________
1997 F350 CREWCAB 4x4 7.3L Powerstroke, 4.10's, Built BTS Auto, Edge Evolution, Dual 5" stacks, Z-Series Gauges, 10K, Tymar Intake, Gutted EBPV, & HPX
  #3 (permalink)
Old 08-24-2007, 03:44 PM
Yea, at least my housing was still useable. Just took out the gears and gouged up the bearings.
Are the guys without rear end problems running Sterling 10.5's, Dana 80's or something else? Open, welded, limited slips, or lockers? -thanks-
  #4 (permalink)
Old 12-30-2007, 09:47 AM
bogginf350's Avatar
bogginf350 is new and has a neutral reputation at this point.
Dana 80 is the way to go... Cheaper route is a gm 14 bolt.
__________________
Josh Davis, FTE resident injector builder.
03 f350 srw 4x4 6.0..
94 f1504x4 shortbox 523ci A heads
79 f1504x4 shortbox 547ci Blue thunders...
  #5 (permalink)
Old 12-30-2007, 08:52 PM
duramaximizer is new and has a neutral reputation at this point.
The problem one of my friends had with a stock Dana 80 was twisting the axils out of it. Aftermarket axil seem to have solved the problem for now. GM 14 bolt is super strong also.
  #6 (permalink)
Old 03-05-2008, 08:51 AM
scottie2hottie's Avatar
scottie2hottie is gaining momentum as a positive member of FTE.
14 bolt axles aren't as strong as an 80 but the 80 has a weak pinion yoke in comparison IMO. Seen two of those break off, one damaging the pinion gear, never seen a 14 bolt break a pinion yoke. Never seen a sterling break the gears...axles though will break. I personally would rather break a shaft than anything else in there, but ideally of course would like to break nothing. Could always upgrade to militarys
__________________
2002 F350 "Big White"
2001 F150 "Black Pearl"
1996 F350 "Red Sled"
1994 F350 "Possum"
1982 F250 "Amos Moses"
1975 F250 "Mean Green"
Quote:
Originally Posted by CMNZ59
Horsepower is how fast you hit the wall, torque is how far you push the wall once you hit it
Proud to be an OHIO BOY
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
