VIN Codes
VIN Codes
Its actually listed on the 'vehicle certification label', which should be on the door frame or jamb. The code listed under 'axle' is one of the following, depending on your model:
31 — 3.73 non-limited slip, F-250/Excursion
C1 — 3.73 limited slip, F-250/Excursion
32 — 4.10 non-limited slip, F-250
C2 — 4.10 limited slip, F-250/Excursion
33 — 4.30 non-limited slip, F-250
C3 — 4.30 limited slip, F-250/Excursion
36 — 4.56 non-limited slip, F-250
C6 — 4.56 limited slip, F-250
41 — 3.73 non-limited slip, F-350 (single rear wheels)
D1 — 3.73 limited slip, F-350 (single rear wheels)
42 — 4.10 non-limited slip, F-350 (single rear wheels)
D2 — 4.10 limited slip, F-350 (single rear wheels)
43 — 4.30 non-limited slip, F-350 (single rear wheels)
D3 — 4.30 limited slip, F-350 (single rear wheels)
46 — 4.56 non-limited slip, F-350 (single rear wheels)
D6 — 4.56 limited slip, F-350 (single rear wheels)
61 — 3.73 non-limited slip, F-350 (dual rear wheels)
F1 — 3.73 limited slip, F-350 (dual rear wheels)
62 — 4.10 non-limited slip, F-350 (dual rear wheels)
F2 — 4.10 limited slip, F-350 (dual rear wheels)
63 — 4.30 non-limited slip, F-350 (dual rear wheels)
66 — 4.56 non-limited slip, F-350 (dual rear wheels)
F6 — 4.56 limited slip, F-350 (dual rear wheels)
81 — 3.73 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E1 — 3.73 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
82 — 4.10 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E2 — 4.10 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
83 — 4.30 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E3 — 4.30 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
86 — 4.56 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E6 — 4.56 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
88 — 4.88 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
EW — 4.88 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
G3 — 4.30 limited slip, F-450 Chassis Cab
73 — 4.30 non-limited slip, F-450 Chassis Cab
78 — 4.88 non-limited slip, F-450 Chassis Cab
G8 — 4.88 limited slip, F-450 Chassis Cab
75 — 5.38 non-limited slip, F-450 Chassis Cab
G5 — 5.38 limited slip, F-450 Chassis Cab
GW — 4.10 limited slip, F-450 Chassis Cab
98 — 4.88 non-limited slip, F-550 Chassis Cab
K8 — 4.88 limited slip, F-550 Chassis Cab
95 — 5.38 non-limited slip, F-550 Chassis Cab
K5 — 5.38 limited slip, F-550 Chassis Cab
KW — 4.10 limited slip, F-550 Chassis Cab
VIN Codes
>model:
Mine is blank. Although, my axles are tagged.
Does anyone know of a site where I can learn how to decipher my VIN?
Hey 3992824, with a comprehensive post like that you gotta know!!
>model:
VIN Codes
Mine is blank, too, monsta. There is a 'UTC' roughly under it, but saying it corresponds to 'axle' would be a stretch.
I figure mine has 4.30 gears since it runs around 2100 @ 65mph. I've only had it a week and those gears let it really LEAVE. No wonder folks get 8 mpg! Once you realize it will take off like that it is hard to ease out into traffic anymore.;-)
JACIII
2000 X V10 Limited
JACIII
2000 X V10 Limited
VIN Codes
I tried this a while back and ended up going to the dealer because of a discussion similar to this but I also checked the tag on the rear only to find some code that even the dealer was not sure of. I did finally figure out that the front end also has a code but it actually tells you what gears you have!
VIN Codes
[updated:LAST EDITED ON 19-Dec-01 AT 00:05 AM (EST)]You know mikeking, I couldn't find the gearing on my rear axle. I only found it on the front. Is yours a 4x2 or 4x2? If you don't find it, post your RPM at 60mph (in overdrive) (indicate auto or 6 spd!)and all us will let you know what your gearing is!:7
VIN Codes
[updated:LAST EDITED ON 22-Dec-01 AT 11:47 AM (EST)]Mikeking, First off the vin # does not in any way indicate the gear ratio. If you can't find a tag anywhere, then take the others advise and list your year, model, engine and rpm at a specific speed. One of us here will surely be able to relate this to you.
Also for those who found questions with comparing your vin # to the link NOMO provided...... The vin combinations change every few years so you need to check the chart for your specific year,also as I looked back this chart is for non-Super Duty trucks. (20 yrs investigating recovered stolen vehicles)
VIN Codes
[updated:LAST EDITED ON 22-Dec-01 AT 11:20 PM (EST)]EDMO
N= GVRW 8501-9000 lbs w/ second generation air bag
w21= F250 SD 4X4 CREW CAB
M= ASSEMBLY PLANT- CUAUTITLAN, MEXICO
NOMO
S= GVRW 9001-10000 lbs w/ second generation air bags
w31=F350 SD 4X4 CREW CAB
M= CUAUTATLAN, MEXICO
NOMO
