Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 08-24-2007, 07:13 AM
jbondi is starting off with a positive reputation.
Question Odd problem
I've been noticing sometimes when I start my truck in the morning, the engine will rev high, the check engine light will flash, then I put it in drive, the rpms fall like the truck is going to stall, then it's fine and the check engine light stays off!! Any ideas??
__________________
Joe
1994 Bronco XLT (302)
Gibson Shorty Headers, Bassani catback
K&N OEM air filter
Alpine AM/FM cd player
MB Quart door speakers
Kenwood rear speakers
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 08-24-2007, 10:25 AM
Kemicalburns's Avatar
Kemicalburns is gaining momentum as a positive member of FTE.Kemicalburns is gaining momentum as a positive member of FTE.
PULL CODES, www.fordfuelinjection.com has instructions using a paperclip, counting the flashes
__________________
94 XLT 5.8/E4OD
6"ProComp Stage II 35x12.5x15 BFG MT's ,
4.88 gears f/r
installing soon: JBA shorty, Bassani Y pipe, Edelbrock efi truck intake, , aussie front/rear
88 (Rolled)
http://www.supermotors.org/registry/vehicles/detail.php?id=4158
  #3 (permalink)
Old 08-24-2007, 09:27 PM
blue beast's Avatar
blue beast is gaining momentum as a positive member of FTE.blue beast is gaining momentum as a positive member of FTE.
If you bump the throttle does the revving stop? Have you ever cleaned the IAC? sounds like its getting stuck.
  #4 (permalink)
Old 08-27-2007, 09:15 AM
Quote:
You mean like in the old days of kicking off the choke? No, haven't touched the throttle when this happens. Are there any write ups on how to clean the IAC??
__________________
Joe
K&N OEM air filter
  #5 (permalink)
Old 08-27-2007, 10:05 AM
have you gone to the website and read up on there. pull codes etc..
__________________
94 XLT 5.8/E4OD
4.88 gears f/r
88 (Rolled)
  #6 (permalink)
Old 08-27-2007, 10:33 AM
Quote:
I searched through the articles and couldn't find anything pertaining to the IAC on a Bronco. Haven't pulled codes yet, just wanted to see what was involved with cleaning/replacing the IAC.
__________________
Joe
K&N OEM air filter
  #7 (permalink)
Old 08-27-2007, 10:45 AM
blue beast's Avatar
It is easy to clean a can of carb cleaner pull off Iac and you should see the plunger in there all gunked up. Spray it liberally until it's nice and shiney. Make sure you hold the motor up or else all that gunk will go back inside it. On a cold start your truck should rev up then a tap on the gas will make it go to a normal idle, or wait 90 secs and it will go down itself!
__________________
86 fs bronco 302 auto 33x12.50 at rusty but trusty!
04 Ranger edge 3.0 5 speed auto 4.10
Before posting fuel related problems Run a couple of bottles of dedicated gas line dryer through IT!!!!!!!
There now I don't have to say it every time!!!!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
