I just bought a 03 SD 4x4 and I want to run a synthetic. In my f-150 is used Mobil-1 syn and changed it about every 10,000. It had 155,000 and ran quiet as a mouse. Should I stay with Mobil 10-40 syn ?
Make sure you use a diesel rated oil, for sure. These oils are designed to hold and suspend various by-products that only diesel engines produce. That is a key factor, but I still stand by my 5w40 Shell Rotella-T recommendation.
Rotella T 5W-40 is quite a product. It is significantly less expensive than most full-synthtetics and yet it meets not only API deisel specs, but some very stringent VW and other proprietary specs as well. The base oil is Group III, but more like Group III+, becuase it is made by a different process. Shell Helix Ultra is made with the same base oil and is factory fill for Ferrari.
