Modular V10 (6.8l)
v-10 cam specs
Old 12-05-2001, 10:55 AM
job1bf's Avatar
job1bf
job1bf is offline
v-10 cam specs
Can someone provide me with or tell who can on cam specs. for the v-10(00-02). Lift, duration, etc...it would be greatly appreciated
Old 12-05-2001, 01:26 PM
NoMo's Avatar
NoMo
NoMo is offline
v-10 cam specs
CAMSHAFTS — Type 6-Bearing, Machined Steel
Material Tubular Steel With Powdered Metal Lobes
Journal Diameters - in. (mm) 1.061 (26.95)
Cam Lift: Intake — Exhaust - in. (mm) 0.259 — 0.260 L.H./0.259 R.H. (6.58 — 6.60 L.H./6.59 R.H.)
CAMSHAFT BEARINGS — Type Aluminum Housing SOHC Cylinder Head
Material Aluminum
Total Effective Length - in. (mm) 0.590 (15)
Total Effective Surface Area - sq. in. (sq. mm) 0.628 (405)
CAMSHAFT DRIVE — Type Silent Chain
Sprocket Material Sintered Steel
Old 12-05-2001, 04:39 PM
Redv10's Avatar
Redv10
Redv10 is offline
v-10 cam specs
This page has (almost) all the information you could want. I suspect
it's where NoMo grabbed the information that he posted:
http://fordtruck.fordtraining.com/f250/html/spcfrm.htm
Old 12-05-2001, 07:02 PM
NoMo's Avatar
NoMo
NoMo is offline
v-10 cam specs
Yup. I saved that one page regarding the V10 down to my disk. A lot easier to find. ;-)
Old 12-19-2001, 11:27 AM
job1bf's Avatar
job1bf
job1bf is offline
v-10 cam specs
Thanks guys..the info is just what i was looking for..
job1bf
Old 01-19-2002, 09:31 AM
NoMo's Avatar
NoMo
NoMo is offline
v-10 cam specs
Old 01-21-2002, 09:02 PM
Bullriding_FordGuy's Avatar
Bullriding_FordGuy
Bullriding_FordGuy is offline
v-10 cam specs
Do you know if they have one of them pages for 2001, or would the 2002 page work? Thanks for your help in advance. JP
Old 01-21-2002, 09:11 PM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
v-10 cam specs
[updated:LAST EDITED ON 21-Jan-02 AT 10:12 PM (EST)]For the most part, that page referenced above will "work" for your '01. Do keep in mind that there are some mistakes on those pages so they shouldn't be considered gospel just cause they are from Ford. However, the mistakes that I noticed; I noticed right off. In other words, they are pretty simple mistakes.
It's best really to check your info here and there and even somewhere else, just to be safe. There have been changes for the '02 models but not to the V10 in particular. I know I screw up a lot but luckily there are guys here who straighten me out in a hurry. I believe this site is the best info source out there.
Old 01-21-2002, 09:30 PM
rsjohnsn's Avatar
rsjohnsn
rsjohnsn is offline
v-10 cam specs
This isn't about cam specs but it got my curiosity up. I copied this from the above link:
Fuel Metering System Sequential Electronic Fuel Injection — Eight Port-Mounted Fuel Injectors Electronically Triggered by EEC-V Module
I thought this was a V-10? Is this one of the mistakes you were talking about or am I going crazy? Never mind that question, I am crazy! Is there 10 injectors or just 8?
Thanks
Scott
Old 01-21-2002, 09:33 PM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
v-10 cam specs
See I told you there were mistakes!!
Grimblore
Modular V10 (6.8l)
01-22-2016 09:00 AM
86stepsideF150
69
11-07-2015 04:43 PM
pintoches
05-17-2011 08:15 AM
BigDave74
06-10-2007 10:03 PM
cfrives3
1978 - 1996 Big Bronco
05-21-2007 06:03 PM
Quick Reply: v-10 cam specs
