Stock Ponies
yeah but look at what you are turning, look at the size of your torque converter and the size of the trans, also think of how hard it is to turn the rear yoke with it jacked up, you lose alot of power through the drivetrain thats why engine dynoes suck and chassis dynos are the truth tellers
i have an article from early 1999 and they tested the first 99 model sd with the first superchip, pedal, intake and propane. they did a dyno pull with it stock, i will upload it tomarrow. the truck was a 6-speed so it will give you an idea for the sticks but remember you lose a lot more horse power and torque turning an auto
lol, sorry i forgot about it, here is the article in the house, the other on a 99 7.3 is in the shop, i'll get it tomarrow, but this gives you a good idea of the comaprison, 50 horsepower drop in a 6.0 and 127 ft pounds, and the torque shift has better bearings then a e4od, so assuming it is the same, a 97 psd would have, 175 rear wheel horsepower and 348 ft pounds
not only the tranny but the diffs as well, the full floaters we have are good for as big as they are, the trannies depend on the overall size and friction areas inside, alot of the newer stuff uses roller bearings instead of thrust washers, that is the main thing you can do, it lowers heat and reduces the ponies used to turn it
Rtbcoop
19
06-30-2016 08:22 AM
