'01 pmr or forged???
No problem. It is not that easy to see in there but it can be done. I used a large socket and breaker bar on the crank rather than trying to bump the starter around to align the rod end for viewing. Good luck.
EDIT: BTW, it just occurred to me. I remember it was a PITA shining a light in that hole while trying to look in at the same time. It's dark in there. I think this can be done far easier during an oil change with a slim penlight shining through the oil drain hole while you look through the inspection hole. Just a thought.
Originally Posted by cookie88
On almost every truck I've checked the engine build date is within a week or so of the truck build date. I have no doubt that you have PMR's as 4/01 is well after the switch was made.
Thanks Billy
Originally Posted by alstieg
My motor was built in nov '00 and the conoa plant. probably the pmr's.
JacoFordCummins
Engine Swaps
45
11-04-2020 09:09 AM
homesteader
16
03-12-2010 03:11 PM
