Decent Sound system?
#31
#33
Originally Posted by strokin_it7.3
cyrex, the 2dims won't fit in my dash i have the older truck remember... Drbalazo, that is perfect, just what i priced on crutchfield but it's $100 cheaper.
First, you will need a double din kit:
Metra 1995-Up Ford/Mercury/Mazda Installation Kit
Cost: $19.99
Kit: 995805
http://www.circuitcity.com/ssm/Metra...oductDetail.do
Picture:
End Result:
You will have to shave the top and bottom of the radio opening a little to fit the avic (there is a small lip there - you will not notice once it's put back together).
Harness is a 70-1771
Info taken from: http://avic411.com/forum/viewtopic.php?t=8808
#34
I also am not a big fan of Jensen products. They do not last.
You can fit a double din unit like one_wicked was saying. I had one in my 99 F250. It really isn't all that hard. Just take the dash panel out of the truck and use a dremel to grind out the upper and lower lip inside the radio opening. Just grind it until it is flush with the main flat area around it. Leave the lips on the sides as that is what the install kit that one_wicked suggested hooks on. Also, by leaving them it will allow you to put the stock stereo back in if you get rid of the truck. There was also a screw and a clip in the radio opening on the dash structure in the truck that you have to remove.
Crutchfield has a good selection and great customer service, but they are expensive compared to other online retailers.
I would suggest you buy the Kenwood DDX-7019. It's a bit more than you were hoping to spend but it will be worth it in the long run.
http://www.sonicelectronix.com/item_8777_Kenwood+DDX7019+-DDX-7019-.html
Then you can get the Ipod cable iP300V for video ipods, or iP200 for regular.
http://www.sonicelectronix.com/item_9141_Kenwood+KCA-iP300V.html
http://www.sonicelectronix.com/item_...KCA-iP200.html
That will probably take up most of your budget now. If you decide you want more bass, start saving your money and then get one of these boxes with two Image Dynamics IDQ10s.
http://www.supercrewsound.com/shop/detail/11/48.htm
#35
Originally Posted by GregsSD
I don't know if anyone has mentioned it (cough,cough) but the pioneer AVIC-D3 is awsome!!!
I love having the navigation, dvd, ipod interface, backup cams, and it's all very easy to use.
Here's Mine:
Here's Mine:
#36
As to Crutchfield as has been stated they have excellent customer service and are quite knowledgeable. That said, the customer service and knowledge comes with a price as they are generally quite expensive.
#37
Kris,
I have the Jensen VM9312 and I am kinda on the fence..... I have a few friends that work in local stereo shops and they have all had bad experiences with the screens failing. I have used it for about 4 months fairly trouble free. My issues have been: I cannot get the clock set any time I set it a minute later it changes to exactly 7 hours slow. It doesn't bug me to much so I just kinda deal with it. I feel it is a little slow to open and close. And last sometimes when using the XM function I get no sound and or when I select a station the touch screen doesn't register. Other than these few issues I have not had any major issues. installation was extremely simple other than the fact that there are so many damn connections you almost cannot fit all the wire behind it. I will try to post some pictures today.
Sorry for the long post.
#38
Thanks for all the continued input. I actually really wanted a double din indash unit, i don't prefer one that flips out and etc, youre all right, just too much to break. I like the fact i can fit that in my truck and i've had the dash off several times... I am going to keep looking around... If any of you can point me to the following it would be great: CD/DVD player, radio tuner, double din indash screen, with outputs for connecting my iPod and possibly a USB connection. I do not want navigation or GPS, no satellite radio. I love the AVIC and how it looks but i dont want the navigation. Does Pioneer make something similar without the navigation but still relatively the same features? Ive been going over the Kenwood ddx7019 and looks appealing so far. Question, can i adjust the colors to match my factory green lights and the green gauges in my cab. I don't know why, but alot of HU's i see are blue?
#39
first of all, i would stay away from sony's head units..
i have a pioneer i cant find the box to remember the model number but it is very similar to this one here .. http://www.pioneerelectronics.com/pn...194603,00.html
its not the most expensive or best on the market by any means but it looks great in my truck and i love the color
as you can tell by the picture, it is mostly blue, however the green lights you can see in there too match the stock green lights perfectly. when i get gauges i am going to get blue to match the cd player so i have both a mix of green and blue
#40
on
#41
As far as I know you can change the background to custom images on the DDX7019 (I can't on my 6019). I can't remember what color the buttons light up on it, but it doesn't realy matter because there is only like 6 really small buttons, that you don't even really notice when they are lit up. The maority of the functions are controlled from the touchscreen. I will try to pay attention tonight and see what colors they are when I drive home.
#42
I love my ipod hookup. Alpine, Pioneer, and Kenwoods are good units. I had a JVC and i blew it up, i have a pioneer in my closet from about 4 years ago and it still works. My alpine probably has the best sounds out of all of them though, but i dont know if they make a in dash screen though, and they are pricey. The kenwoods are nice, my buddy has one in his truck. It weird watching a movie in a truck to me.
#43
on
#44
Originally Posted by WheelMA1
You do not happen to have the Audiophile setup with this HU, do you? Its a slick unit, and certainly something that I might consider. I would want to use it though, with the Audiophile packaged speakers and amp. Thanks
Later on I will add an amp and subwoofer.
Some info for everyone, with the avic-d3 you can load your own background picture and you can customize the button colors to any color you want.
