rusted brake lines - Ford Truck Enthusiasts Forums
rusted brake lines
Old 08-22-2007, 09:03 PM
48super6 48super6 is offline
48super6 is starting off with a positive reputation.
Cool rusted brake lines
2000 Ex v10
Did anyone else have any problems with rusted out brake lines? My ex is in great shape and doesn't see much bad weather - it only has 35,000 miles. I was heading down a steep hill to a busy intersection the other day and I stepped on the brake, began to slow, but then my foot went to the floor. It continued to slow a bit (pumping didn't help) and I wound up taking a fast left into the intersection- luckily no one was comming. Certainly a white knuckle experience. I nursed it back home and found rusted brake lines, leaking about midway along the frame. (everything else under there is pretty clean - no rust)
I spoke to 2 different mechanics who said it wasn't that unusual for Ford trucks because of the way they mount the the lines- although many never have the problem at all.
Any one else experience this? Is it worth replacing the lines with stainless ones? I also thought since I'll be replacing the lines, I'd look into replacing the hoses and flushing out the whole system. Has anyone replaced the rubber hoses with stainless steel wraped ones? Does it reduce any of the spongy-ness of the stock system? Is it worth it? Any sources?
Any thoughts on the subject(s) would be appreciated.
Old 08-23-2007, 01:20 AM
RACERX7775's Avatar
RACERX7775 RACERX7775 is online now
PROFESSIONAL KNOW-IT-ALL
RACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to behold
hmm, makes me wonder about mine. glad to hear that you didn't get into an accident. i think i'll take a look under mine tomorrow.
Old 08-23-2007, 10:49 PM
mudman00x's Avatar
mudman00x mudman00x is offline
mudman00x is gaining momentum as a positive member of FTE.
Had To Replace Mine This Winter I Was In A Hurry So I Used Steel, I Replaced A Buddys And He Like You Had Low Miles 39000, So I Think Its A Problem, If It Sits It Will Rust, Oh Ya Mines A 2000 4+4 That I Use More In The Winter, I Live In The North East So Salt Doesnt Help,n I Bled The **** Out Of Mine And Changed The Front Rubber Lines As Well.
Old 08-25-2007, 08:36 AM
Talking to a few others, it does seem to be a problem. The clips seem to be the place to look first, even if the rest of the line looks good (mine looked pretty rusty along the whole length).
When you replaced the rubber lines, did you use the stock lines or the stainless jacketed ones?
Old 08-26-2007, 10:40 PM
mudman00x's Avatar
rubber factory lines
Old 08-27-2007, 11:42 AM
Matt M, PA's Avatar
Matt M, PA Matt M, PA is online now
Matt M, PA has a very good reputation on FTE.Matt M, PA has a very good reputation on FTE.Matt M, PA has a very good reputation on FTE.Matt M, PA has a very good reputation on FTE.
My former '94 Bronco had a similar problem. Had the front to back line go...while towing the trailer. I used the trailer brakes and managed to limp to a garage.
I was about 50 miles from home to go the Mopar Atlantic Nationals with my '72 Plymouth. I found a local garage willing to do th repair while I was at the show. I drove my Plymouth to the show and left the truck for the fix.
The rest of the lines showed no serious rust issues, and it was find until I sold it.
I guess I was in some ways fortunate to have the trailer with me for it's brakes...but it got lots of brake fluid on it.
Brakes acting weird on hard stops Codelizard Excursion - King of SUVs 9 10-16-2015 03:21 PM
Brake Stuff for 79 4x4 tjac 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-03-2015 07:35 PM
Brake Lines Vadis 1987 - 1996 F150 & Larger F-Series Trucks 15 01-03-2015 08:11 PM
Stainless brake system helirich 1999 to 2016 Super Duty 28 09-28-2014 03:49 PM
Pre-bent brake lines capriceragtop 1987 - 1996 F150 & Larger F-Series Trucks 15 10-15-2013 06:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
