Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 08-22-2007, 08:15 PM
madcapper is starting off with a positive reputation.
EGR Low Volume
I am going to replace my EGR valve, it throws a code low volume. My question is after I take the old one off can I just blow some compressed air up in there where the EGR mounts to clean it out or will I damage something.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 08-24-2007, 07:51 AM
projectSHO89 has a good reputation on FTE.projectSHO89 has a good reputation on FTE.
Quote:
You are wasting your money replacing the EGR valve. They rarely fail.
You need to do some diagnostics.
Get your fault code and SEARCH for previous discussions pertaining to it.
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #3 (permalink)
Old 08-24-2007, 08:06 AM
Can't move the shaft on the old one, needs to be replaced. If I use compressed air through the EGR hole will it hurt anything...is the question.
  #4 (permalink)
Old 08-25-2007, 07:15 AM
s1120's Avatar
s1120 is starting off with a positive reputation.
Probably will not do anything good. If your intake is set up like the 3.8 Windstar I just did, there are small holes in each runner that lets the ex gasses into. They tend to plug, and blowing air will only shot it out of the unplugged ones. Won't do any good, and can possabley blow chunks into the intake ports.
When you do the valve, I would look hard at bolth the egr tube, and also the DPFE sensor. those are much more common to go bad.
__________________
Paul B
95 Bronco, e40d,5.0HO shortblock, early 351 heads, ported w/1.94/1.60 valves, Crane 2030 cam, shorty headers, homemade Ypipe, and flowmaster cat back[for now]
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
