'01 F150 5.4, sputter while driving
My truck has been sputtering while driving for some time now, and it is on and off. Sometimes I'll go for a couple months with nothing, then it'll start doing it again. It seems like maybe a misfire, or multiple misfires? It used to 'seem' to do it when the drivetrain was between acceleration and slow down. But now it is also doing it during acceleration. I have taken it to the dealership, but of course it wouldn't do it when they had it and their equipment shows no problem.
Anybody had similar experience?
Thanks!
Thanks!
Another consideration - water in fuel
Always consider water in your gas tank when you have intermittent misfiring. The widespread use of ethanol in gasoline has made this less common than it used to be, but it still happens. A sudden drop in temperature or rise in humidity can cause water to condense inside your tank even if your fuel supply is reliable. I once blew $140 at a "service station" for this very problem which they never even considered. I called my dealer 500 miles away, they diagnosed the problem over the phone & I cured it completely in 10 minutes with 2 cans of "dry gas" to the tank. More than a little water in your tank necessitates draining it completely, though.
Bootlegger's Deluxe
Modular V8 (4.6L, 5.4L)
03-12-2016 08:51 PM
fteduran
1999 to 2016 Super Duty
06-24-2011 07:48 AM
