94 Explorer Start Issue - Fuel Pump Relay?
Old 12-08-2015, 07:23 AM
Redfridge's Avatar
Redfridge
Redfridge is offline
Found my fuel filter was the problem on mine.
Turned the key on and off 3 times to push some fuel through for awhile there and it started no problem.
Old 03-11-2016, 05:16 PM
Edward Morgan's Avatar
Edward Morgan
Edward Morgan is offline
I got a problem with my 96 explore 4.0 it runs good but hesitate and die but cranks every time what u think
Old 03-11-2016, 05:18 PM
Edward Morgan
It will sit and run but put in in drive it like it's not getting any gas
Old 03-11-2016, 09:14 PM
shorod's Avatar
shorod
shorod is offline
So basically your Explorer dies as soon as you put it in Drive? I'd suspect either a low battery (that drops the system voltage too much when the engine is put under load and the brake lights are on) or you may have a vacuum leak that causes the engine to stall when a load is placed on it. If you very carefully, and preferably in an open area, give the truck some throttle when shifting to drive while firmly holding the brake pedal, will the truck remain running? If so, does it run rough under load?
When is the last time the truck had a tune up (spark plugs, plug wires, air filter, fuel filter)?
-Rod
Old 03-12-2016, 05:29 PM
Edward Morgan
I tuned it up like 2 weeks ago
Old 03-12-2016, 05:30 PM
Edward Morgan
Some people say it might have water in the gas
cokeman
Modular V10 (6.8l)
40
03-07-2022 08:09 PM
nomad27
Modular V10 (6.8l)
23
03-03-2019 02:55 AM
Bigweasel
08-13-2017 08:23 AM
BackyardBronco94
1978 - 1996 Big Bronco
05-15-2017 08:25 AM
JDSIMPSON55
03-17-2017 04:11 PM
Quick Reply: 94 Explorer Start Issue - Fuel Pump Relay?
