How to adjust torsion axles? - Ford Truck Enthusiasts Forums
Old 08-02-2007, 11:58 AM
Phantom6 Phantom6 is offline
Phantom6 is starting off with a positive reputation.
Question How to adjust torsion axles?
I have a Tundra 5th wheel BH that has the rubber torsion axles. My 06 F-150 SC 5.4 Lariat sits higher than the level trailer. I understand the axle can be set at three settings, -25, 0 or +25, but no one knows how to do it. Has anyone heard of doing this other than changing out the axle with a Dexter? Thanks again for a GREAT site!!
Old 08-21-2007, 05:52 PM
horsepuller's Avatar
horsepuller horsepuller is offline
horsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputation
Welcome to FTE and thanks for joining us in the Towing forum!
Old 08-26-2007, 07:34 PM
kenadian's Avatar
kenadian kenadian is offline
kenadian is starting off with a positive reputation.
The only adjustable torsion axle I know of is the Flexride. It is splined, and can be adjusted by removing the hub and rotating it right/left to increase/decrease the current ride height.
http://etrailerpart.com/torsionaxles.htm
Here's Dexter's link and info
http://dexteraxle.com/torflex_axles
Torsion suspension question... AhoyMatey 1997 - 2003 F150 4 04-11-2014 06:04 PM
torsion bars for towing blue924.9 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 2 08-07-2013 03:04 PM
Torsion axles V/S Leaf spring suspension?? Supercab Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 10 10-10-2011 12:37 PM
how do I get the torsion bar adjuster off torsion bar? turbo740922 1997 - 2003 F150 1 03-05-2011 04:34 PM
aftermarket torsion bars dogman Explorer, Sport Trac, Mountaineer & Aviator 0 10-30-2005 07:37 PM
Tags
adjust, adjustable, adjusting, adjustment, axle, axles, f150, ford, howto, maintenance, rubber, specifications, torsion, tow, trailer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
