Raybestos Quiet Stop Ceramic Pads?
The shims should be used, as they and the black stuff helps to keep the pads from squeeling. Put a little dab between the shim and the pad. (That is, unless they put something with the ceramic pads different than standard pads).
http://easyad.net/images/94vanavitar.jpg http://www.easyad.net/images/mustang1.gif
'94 E-150 Conversion Van 4.9 / C-6 -- '89 Mustang LX 5.0
The shims have what appears to be a plastic film on one side. You pull it off and there's adhesive on it. I'm assuming you press that on the backing plate of the pad? Do I apply the black stuff to the non-adhesive side of the shim after placement onto the pad backing plate?
Here's a pic of the pads and shims. I laid one shim on one of the pads.
http://www.my9n.freeservers.com/temp/Misc/pads.jpg
Thanks,
Tyman
Thanks,
Tyman
I wouldn't put anything between the pad and caliper piston. I suppose they use the self adhesive shims in place of using the quieting goo.
I have no idea what the black stuff is you mention. Is there any labeling? Open it and see if it's a lubricant as you suggested, or glue type stuff.
