Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 08-21-2007, 12:42 AM
3Nails is starting off with a positive reputation.
Towing a '91 4X4 Bronco
I tow my ’91 4X4 Bronco occasionally. I’ve always dropped the rear drive shaft when towing. Do I need to go to all the trouble?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 08-21-2007, 01:19 AM
351c is starting off with a positive reputation.
I've always heard that it protects the transmission which is not getting lubed with the engine off
  #3 (permalink)
Old 08-21-2007, 10:45 AM
86BroncoGuy is starting off with a positive reputation.
if u dont youll rack up a lot of extra miles
__________________
1992 Ford Mustang LX convertible
2001 Jeep Grand Cherokee
1986 Ford Bronco-351w, Headman headers, 6in. superlift, 3in. body lift, 35" PRO-Comps
1978 Ford F-150 Custom 4x4
1984 Mercury Grand Marquis-400hp 331 stroker
1965 Ford Mustang Fastback
  #4 (permalink)
Old 08-21-2007, 10:17 PM
blue beast's Avatar
blue beast is gaining momentum as a positive member of FTE.blue beast is gaining momentum as a positive member of FTE.
Just put the transfer case in neutral should be fine
  #5 (permalink)
Old 08-21-2007, 10:30 PM
Thanks, Guys, but now I'm confussed. Do you know of anyone who has actually towed? Would hate to tear up something.
  #6 (permalink)
Old 08-21-2007, 11:39 PM
mrknight01's Avatar
mrknight01 is starting off with a positive reputation.
it should tell you in your Owners manual.
You should never tow a 4x4 unless the transfurcase is in neutral or the drive line removed .
__________________
Roads are for wimps Off Road for life
95 Bronco 351(5.8) / E4OD BFG's 32 11.50 15"
93 Explorer 4.0 / A4LD
84 Bronco 351 H.O.4V / C6
72 F250 429 / C6 R.I.P.
  #7 (permalink)
Old 08-22-2007, 01:42 AM
ag30265's Avatar
God,Family,Guns & Trucks
ag30265 is gaining momentum as a positive member of FTE.
It all depends upon how you are towing it. If all wheels are on the ground- the trans case should be in neutral and the rear drive shaft removed. If you tow it often there are kits that can be purchased and installed on the rear shaft that will dissengage it without removal. They have a slip joint that is installed on the shaft and can be moved to engage it or dissengage it.....great for rec towing but bad if the vehicle is used for offroading or rough driving(weak link).
If towing with two wheels on the ground- rear wheels up on dolly or lift- strap the steering wheel in the straight position and haul on! Hub styles don't matter but I always put the trans case in neutral with auto lockers.
Front wheels up on dolly or lift- remove the drive shaft/dissengage it and put the trans. case in neutral.
Towing from the rear with the drive wheels off the ground is the safest and quickest option for a bronco or other 4x4 vehicle.
The issue with towing w/o removing the rear drive shaft is the back bearing in the tranny, it will burn it up and damage other parts of the tranny. With a manual odometer it will add mileage if the shaft is left in key on or off.
When I have to remove a driveshaft to pull a vehicle I will remove the bolts from the pinion and slide the shaft toward the tranny(if slip yoke equipped) or move it to one side and use a rachet strap to hold it up and away from the pinion, as the pinion will rotate when going down the road.
mrk is correct, the owners manual will tell you about towing for recreation but will tell you to call a qualified towing company for road side assisstance. That's where we come in
__________________
"Always mystify, mislead, and surprise the enemy...repeated victory will make you invincible. Have faith in God that the victory will be won, irregardless of odds." --- Gen. T. J. Jackson
Club SNL- #13
'87 Bronco(daily driver)
'91 F-150(ole faithfull)
'78 F-150 4X (F. O. Resto)
'76 F-150(parts)
'77 F-150(wifes ride)
  #8 (permalink)
Old 08-22-2007, 07:27 AM
jem270's Avatar
jem270 is starting off with a positive reputation.
This is out of the 96 owners manual.
Towing Four-Wheel Drive Vehicles With a Lever-Operated Transfer Case
Place transmission gearshift (automatic or manual) in N (Neutral).
Lock steering wheel straight ahead if vehicle is to be towed with rear wheels off the ground. Set manual locking hubs in FREE position or disengage the automatic locking hubs by shifting the transfer case to 2H and drive the vehicle in the opposite direction for a minimum of 10 feet (3 meters) in a straight line.
NOTE: Confirm by observation that the front driveshaft is not rotating prior to towing with the rear wheels off the ground.
Place transfer case in N (Neutral).
NOTE: The transfer case neutral setting is located between 4H and 4L. In order to place the transfer case in neutral, first place the lever in the 4H position, then push down (toward the ground) on the shift knob and at the same time pull slightly rearward until the lever is between the 4H and 4L position. With the ignition in the on position, both 4x4 and LOW RANGE indicator lights will be off when the transfer case is in neutral. These lights will also be off when the transfer case is in the 2H position.
There are no wrecker or recreational vehicle towing restrictions on method or distance if the above preparations are made. Vehicle speed should not exceed 55 mph (88 km/h). This applies with the front wheels off the ground, the rear wheels off the ground, or both front and rear wheels on the ground.
__________________
1988 EB Bronco - 302 - AOD - 3.55 Lim Slip 8.8- Manual Hubs and Transfer Case - BFG 32/11.5 AT - 209,000 miles
  #9 (permalink)
Old 08-22-2007, 07:35 AM
jem270's Avatar
Towing Four-Wheel Drive Vehicles With Touch Drive Electric Shift Transfer Case
Place transmission gearshift (automatic or manual) in N (Neutral). Place transfer case in 2H.
NOTE: Both the 4 x 4 and RANGE indicator lights in the instrument panel will be off when the transfer case is in 2H.
ground. When towing your vehicle with the rear wheels off the ground, the front axle
automatic locking hubs must first be disengaged by shifting the transfer case to 2H
and moving the vehicle forward for a minimum of 10 feet (3 meters) in a straight
line. Do not exceed a vehicle speed of 55 mph (88 km/h) while towing.
When towing your vehicle with the rear wheels on the ground or all four wheels on
the ground and the driveshafts connected, do not exceed 35 mph (56 km/h) or
transmission damage could result. If a distance of 50 miles (80 km) is exceeded,
disengage the automatic locking hubs and disconnect the rear driveshaft from the axle
and secure. (Max speed 55 mph [88 km/h] with driveshafts disconnected.)
__________________
  #10 (permalink)
Old 08-22-2007, 11:32 AM
I think I've got it. Exactly what I needed to know. Thanks again!!!!
  #11 (permalink)
Old 08-22-2007, 01:35 PM
jem270's Avatar
What do you tow your bronco with and how do you tow it?
__________________
  #12 (permalink)
Old 08-22-2007, 02:57 PM
' 99 F350 4X4 CrewCab dually 7.3 powerstroke. Tow it with all four wheels on the ground, transfer case in neutral, transmission in neutral, rear drive shaft removed, steering column locked.
  #13 (permalink)
Old 08-22-2007, 03:01 PM
jem270's Avatar
Do you use a tow bar bolted to the front of the bronco?
__________________
  #14 (permalink)
Old 08-22-2007, 03:09 PM
Yes. "U" bolts bolted to the bumper using existing bumper bolts to the frame. Easy pin disconnect.
  #15 (permalink)
Old 08-22-2007, 10:01 PM
mrknight01's Avatar
Any towing with the driveline in should only be for a short distance and not over 45mph. With an automatic transmission, leave it in park so that none of the Trans will turn and the transfer case in neutral. The transfer cases that ford uses now have a small fluid pump in them for lube. With a standard trans it should be in natural as well.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
