this is the code i keep getting with my hypertech III on when i take it off the code never comes back. is there a good reason for this or is it just somthing that happens?
as long as the tune is set to stock i have no code. but if i tune it the code pops up. i was just wondering if the tune pushes the boost up and the wastegate is just going bad and wont work at the higher setting
ok now no matter what i get the dtc now. where do i start to fix this? will just the WW fix this code? or is it going to start adding up into one big bill? i thank you for your help in advance.
When I was running the Hypertech I used to get that code all the time. When I switched to a DP tuner it no longer comes up instead I get a code p1211 all the time. It show up usually after I have my foot in it.
