catalytic heat shield rattle
The heat shield on the drivers side rattles at 1000 rpm...not at idle not at 1500...at 1000.
I grabbed the heat shield after starting up the engine...and of course the rattle stops.
i do not see any place to tighten up the heat shield..
it seems to be a waste to replace the cat because of the heat shield.
there does seem to be some space between the shield and the cat..
any thoughts of wedging a piece of steel in there to stop the rattle..
or any other solution..? maybe i am missing an area where there might be a bolt... it just seems that the shield is integrated with the cat.
Originally Posted by Frat-man-du
Should have a bolt or two - might have rusted off - I had this on my 2002 F-150, 1994 E-150 and 2000 Mustang... get the picture...
i also have the factory paper manuals... i'll see if i can find something there..
any other ideas appreciated..
thanks
All of mine had 2-4 fasteners that attached to either weld nuts or speed nuts. On both the van and the truck I had to cut off the speed nuts as the heads of the bolts had broken off and the shafts had rusted solid to the speed nuts. Pretty easy with dremel and a cut off wheel. I used grade 5 Stainless fasteners and speed nuts - no issues since.
well, i could be wrong.... but i don't think it is something inside...but there is room for something to get in there....
all of your thoughts and ideas are great.... i won't know more until i jack it up and see if there are bolts missing... if i can't spot bolts... i will surely clamp it... i like that idea a lot
