Go Back   Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-19-2007, 09:02 PM
MoneyMaker MoneyMaker is offline
Garage is empty, add now
MoneyMaker is starting off with a positive reputation.
57 Ranchero Questions---Please Help a Newby
Ok here is the story...
I found a 57 ranchero sitting in the weeds on an old farmer’s property. I am a little interested in it but don't know anything about Ranchero's. This one has duel headlights so from a google search I thought it must be either a 58 or 59. With only that information I asked the old farmer what he planed to do with the car and he asked be if I wanted to buy it. He told me that it has been parked there since the 60's and that it had been wrecked and he had a 58 front end put on it. I asked him what he wanted for it and he said "what'll you give?" I offered a very low amount and he said OK. I told him I wanted to go back and look the car over one more time before I commit. That happened yesterday and I need to get back to him early this week but I know nothing, and I mean NOTHING about early fords. Hence my posting, I need some insight on this car.
  #2 (permalink)
Old 08-19-2007, 09:03 PM
My main questions are how do I determine what engine is in it? It may not be the original. What are the most desirable engines?
What were the options for the transmission?
Any problem areas I should look out for?
Any other rare options I should look for?
What is a complete (W/ wrong front clip), non running project worth.
  #3 (permalink)
Old 08-19-2007, 09:05 PM
I have a strong automotive background and have built several vehicles so I am confident I can assess the engine and electrical, if it has an auto tranny then I'll need to look to outside help but will assume that a complete rebuild is in order. My plan is to get this vehicle running and rolling under it's own power. At that point I will determine how much further I want to go with it. From my research a perfect car can be priced in the high $20k's and on the average a very nice restored car is about $15k. Does that sound about right?
I plan on going out to the car tomorrow after work and I'll report what I find. Also I'll try to post some links to some pics of it, after I take them.
If I'm forgetting anything please feel free to ask; and thanks in advance for the help.
I guess my post was too long; I kept getting errors so I cut it in to pices.
  #4 (permalink)
Old 08-20-2007, 04:17 AM
charlie12345 charlie12345 is offline
charlie12345 is starting off with a positive reputation.
Try here: http://www.ranchero.us/cgi-bin/ultimatebb.cgi
Charlie
  #5 (permalink)
Old 08-20-2007, 05:20 AM
Col Flashman's Avatar
Col Flashman Col Flashman is offline
Col Flashman has a good reputation on FTE.Col Flashman has a good reputation on FTE.Col Flashman has a good reputation on FTE.
The original engines & transmissions are either, a 223 I-6, 292 or 312 Y-block w/ either a Single or Dual Range Ford-O-Matic or a Cruise-O-Matic.
The '58 front-end will have the same front-end that Custom 300's & 500's had, which is a big open grille w/ a bar that runs the length of it w/ one that is centered & conects to the bottom of the grille.
The hood will also open away from the Windscreen, same as a suidside door opens reverse from a normal opening car door.
__________________
Cheers
Colonel Flashman
Vermilion '58 Mercury M-100 HP 312 I-6 w/ HP C-4
Blue '58 Mercury M-100 Panel 223 I-6 w/ M-O-M
Black 1893 Henry Ford Quadra-Cycle (replica)
My Replies Are Not Meant In An Offensive Way.... Ever, They Are Merely.... Straight Answers or Comments
  #6 (permalink)
Old 08-20-2007, 09:19 AM
Charlie, Thanks for that link, tones of info there.
Col. Flashman, How do I determine if it is the 292 or the 312? Is there an engine decoding guide out there somewhere? And what is a "Y-Block"?
  #7 (permalink)
Old 08-20-2007, 02:46 PM
Here are 3 links that should help answer your questions.
The Y-block is just that, as it is shaped like a Y because the area where the crank resides sticks down farther than what was to become standard configuration for Small Block Ford v-8's.
http://www.supermotors.net/vehicles/...sue03-a2-1.php
http://www.ford-y-block.com/Block%20identification.htm
http://www.ford-y-block.com/assemblyerrors.htm
__________________
Cheers
Colonel Flashman
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
