1990 Ranger 4.0 V6 torque specs
on
44 ft/lbs is the torque for the first step. After setting them to that in the correct sequence, set them to 59 ft/lbs. The third step requires that they be tightened an additional 80-85º, which is slightly less than 1/4 turn. I mark the head of each bolt so that I have a reference point.
Also, you are using new head bolts, aren't you? These bolts are torque-to-yield and can only be used once as they stretch when torqued.
Rocker shaft supports are 46-52 ft/lbs.
on
I didn't think it was all that fast, but you're certainly welcome...!
Also, my Chilton's manual talks about installing the intake manifold at the same time as the heads and torquing them alternately. I've never heard of doing that on anything else, you'd just about need two torque wrenches (if using the click type) in order to keep from having to reset the torque wrench for every bolt.
tow2sno
15
09-27-2014 12:12 AM
Ranger2003
1983 - 2012 Ranger & B-Series
05-19-2012 08:25 PM
fuzzyzero
03-08-2004 12:03 PM
swampdog2002
12-28-2003 07:57 PM
