Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-19-2007, 03:31 PM
4x4powerstroke 4x4powerstroke is offline
Garage is empty, add now
4x4powerstroke is starting off with a positive reputation.
1990 Ranger 4.0 V6 torque specs
What are the torque specs for heads and rocker arm for 1990 Ranger 4.0 V-6?
  #2 (permalink)
Old 08-20-2007, 01:10 AM
rocker_topper rocker_topper is offline
rocker_topper is starting off with a positive reputation.
the head bolts are 44 lbs im not sure about the rocker arms sorry if i can find it i will post it
  #3 (permalink)
Old 08-20-2007, 08:43 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
44 ft/lbs is the torque for the first step. After setting them to that in the correct sequence, set them to 59 ft/lbs. The third step requires that they be tightened an additional 80-85º, which is slightly less than 1/4 turn. I mark the head of each bolt so that I have a reference point.
Also, you are using new head bolts, aren't you? These bolts are torque-to-yield and can only be used once as they stretch when torqued.
Rocker shaft supports are 46-52 ft/lbs.
__________________
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #4 (permalink)
Old 08-20-2007, 12:13 PM
Thumbs up Thank-you
thanks very much for your fast response to my ? bout torque specs
  #5 (permalink)
Old 08-20-2007, 08:56 PM
TigerDan's Avatar
1968 Ford F-250
I didn't think it was all that fast, but you're certainly welcome...!
Also, my Chilton's manual talks about installing the intake manifold at the same time as the heads and torquing them alternately. I've never heard of doing that on anything else, you'd just about need two torque wrenches (if using the click type) in order to keep from having to reset the torque wrench for every bolt.
__________________
Tags
00, 1990, 1996, 40, arm, engine, ford, intake, manifold, ranger, removing, rocker, sets, spec, specification, specs, torque, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
