Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Supercharger, Turbocharger, Nitrous Oxide and Water/Methanol Injection
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 11-24-2007, 01:38 PM
OUTPLAYN is starting off with a positive reputation.
Blow-thru carbs dont work?
Are you kidding me?
  #17 (permalink)
Old 11-27-2007, 09:09 AM
Tiremine is starting off with a positive reputation.
Just a little joke between me and Fred.
http://www.ford-trucks.com/user_gall...125311&width=0
  #18 (permalink)
Old 12-02-2007, 06:18 PM
shift1313's Avatar
shift1313 is starting off with a positive reputation.
i know a guy that ran a supercharged blow through setup on a 351w and he kept crushing floats. he now is setting up a twin turbo fi 351. this is in a maverick not a truck but the same principles apply. His carb setup ran pretty good but he always had little problems tuning it. If you dont use the right parts then your asking for problems.
  #19 (permalink)
Old 12-02-2007, 07:05 PM
lsdengines is starting off with a positive reputation.
you either have to run the nitrophyl floats, or fill the brass ones. Tuning a blow through carb properly requires a good bit of knowledge of the inner workings in the metering block of a holley.
  #20 (permalink)
Old 03-28-2008, 10:49 PM
1982bluef150 is starting off with a positive reputation.
http://www.jegs.com/i/Barry%20Grant/...010BT/10002/-1
how bout that
  #21 (permalink)
Old 03-31-2008, 04:27 PM
Guys be carefull with with Demon. I run a supposed Demon BT. Right out of the box it will NOT run and tech support from BG is non-existent. After months of tuning with an LM1 data logger I have it finally running well. I have just about worn the bowl screws out changing jets,resizing the high speed air bleeds,resizing the Idle feed resrictors,opening up the PVCR (power valve channel restrictors) and had to make a BRPV. (boost referenced power valve)Unless you know alot about carburetors or intend to learn alot I recomend C&S or CSU More expensive but worth it. IMHO
  #22 (permalink)
Old 04-02-2008, 12:47 AM
C&S??? or CSU??? what are they?
and how do you boost reference power valves?
or what if you got a real big carb and had the primaries feed it til boost hits and then the secondaries juice the boost... so to speak heh
  #23 (permalink)
Old 04-02-2008, 07:41 AM
Carburetor Solutions Unlimited
C&S Racing Carburetors - C&S Specialties
Both of these companies specialize in blow thru carbs, know they're stuff and offer excellent technical support. You will NOT get that with BG (You have been warned)
As far as I know I am the only one on the site running a blow thru and believe me when I say there is steep learning curve. But, that said you can make HUGE HP with one. 2000+
  #24 (permalink)
Old 04-02-2008, 07:58 AM
cool.... i just wanted to feed my straight 6 a couple pounds so it wasnt such a pig...
what about retarding the spark?? someone told me to stick with the vac advance distributor.... i think the only other option is a electronic boost controller from from like msd or something
  #25 (permalink)
Old 04-03-2008, 08:48 AM
I run an MSD Boost Timing Master. It allows you to take up to 3 degrees timing out per pound of boost.
  #26 (permalink)
Old 04-03-2008, 09:00 AM
royalchoppers is starting off with a positive reputation.
That sounds like a handy setup. No more ping I bet?
__________________
In 4130 we trust.
www.myspace.com/royalchoppers
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
