piped my V-10
piped my V-10
jlsworks; pulled into the the house in the early evening to find my 5" Chrome exhaust tip, turned to solid gold!
She sounds like she got a little warm ! Motorcycle shops carry a product that will remove this. It's fairly common for chrome to turn yellow or even blue from heat. I always told the guys who didn't want their motorcycle headers to turn colors to spray high-temp paint inside their header tubes before they put them on their bikes. The extra coating of paint many times would keep the tubes shiny alot longer because it added a little insulation from the heat of the exhaust. Just put the spray can nozzle inside your tip and move it around until you get a good coating of paint. Make sure the inside is as clean as you can get it with a wire brush, some sandpaper, etc. It works !
Ken 98 E-350 XLT V-10 ClubWagon.
piped my V-10
>>Ok..what do ya think?
>>I just bought a Flowmaster 40 Original Series...3 inch intake..
>Sound good so far...
>>with 2 outputs(on the same side, 2 1/2 inch)...so I'm just replacing
>>the stock muffler..
>$Smart move$
>>with 2 pipes exiting, with chrome tips...no Y pipe...so is it truly dual exhaust??
>Nope. Not in my book ;-)
>>Will it sound good? More than once I thought that the truck had
>>died...it's too quiet!!!...I see Monsta is putting on a
>>40..What kind of sound can I expect?
>Well Lisa, I have not made a sound clip and probably will
>not until I return from my annual vacation July 9th. I will
>say that you will not mistakingly think that your truck has
>died after you put that Flowmaster on. It finally sounds
>like a truck when at idle!
What does it sound like if you take out the muffler,and replace with just a 3"pipe?
>As far as the sound...I do not think that it changed the
>actual exhaust sound, only the volume. Does that make
>sense? I've always known what the truck sounded like
>I just couldn't hear it well enough. The Flowmaster (another
>thanks to Black Rhino) help with that. It is rich and
>powerful sounding. Indeed it will sound like it does now but
>amplified!! It is very nice!
>I, too, like the look of the two side swept exhaust tips.
>Yours should look real nice.
>>the stock muffler..
>$Smart move$
ufvj217
05-04-2015 12:43 PM
superv10
08-22-2005 03:33 PM
