Transmission Fluid Change - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
Old 07-31-2002, 11:15 PM
HiTech's Avatar
HiTech HiTech is offline
HiTech is starting off with a positive reputation.
Old 08-04-2002, 01:11 PM
fsnco13F fsnco13F is offline
fsnco13F is starting off with a positive reputation.
I just did my 50K Transmission flush (had a local Lube Shop do it) I was driving my truck today and noticed that my truck kept shifting repeatedly at 70 MPH, I don't know if it was because of some headwind that my truck was struggling to keep up or what!! I really never noticed it before and now I'm a little nervous. It hasn't done it anymore but still worried me a little. Anybody have any ideas or comments? Maybe something like "you should know better than to have someone else change your fluids!"
Old 08-04-2002, 07:08 PM
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
The best place for this question i sup in the Super Duty forum. The V10 forum is for engine discussions (for the most part) only.
How's your fluid level?
Are you absolutely positive that you have the correct fluid in there?
Old 08-05-2002, 11:06 AM
ken04's Avatar
ken04 ken04 is offline
ken04 is starting off with a positive reputation.
Monsta said;
>fluid in there?
Yes this would be the first 2 things I would look into, especially the correct fluid bit. I would be pretty suspect of having a "jiffy-lube" type shop change my tranny fluid. At minimum wage I always wonder how much concern those quick-lube guys have for my $30,000-$40,000+ (new) truck. You don't see many BMW's, Mercedes-type cars in those places. I don't even let them do my wife's 2.0 liter Zetec Contour's oil. As I change it myself I get a chance to look at the belts, the exhaust pipe(s), the hoses, etc. I know what's going on with all my rigs by taking 15 minutes of my time and changing my own oil and fluids. It's time for a tranny fluid change on the big rig and I'm even going to do that myself, I'll let you all know how much tranny fluid I end up wearing ! I think it takes what, 16 quarts ? I'm going to Mobil 1 synthetic trans fluid @$6 a quart ? Yowzers, that's only the major portion of a hun, plus the filter,,,,,gadzooks !!
Ken 1998 E-350 XLT V-10 ClubWagon.
Old 08-05-2002, 09:50 PM
HiTech's Avatar
I would also suspect fluid type. I have had Ford dealers get it wrong before, much less quick lube places. Take it right back and make them put in the fluid your manual indicates.
-Jim
2001 E-450 Superduty
Old 08-13-2002, 06:43 PM
Just to let everyone know, I did take it back to the shop and had them change it again. No problems this time. I watched them do it the first time and second time, right fluid, checked the levels replaced the filter...everything. I have no idea why it had problems the first time. I can tell you that I do my own maint whenever possible, sometimes do have the time, but you can bet I will make time from now on with a 30,000 dollar truck!!!
Old 08-13-2002, 08:12 PM
daimon1054's Avatar
daimon1054 daimon1054 is offline
daimon1054 is new and has a neutral reputation at this point.
If they drained the convertor then it is very likley that thet did not put enought fluid back in. I have done this the trans slipped and jerked like crazy. Once you drove it then it filled the converter and all you should have had to do is add some more.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 01:40 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
DPSE Roachfood 1987 - 1996 F150 & Larger F-Series Trucks 3 03-11-2002 11:21 PM
Tags
2000, 450, 68l, atf, capacity, change, changing, e450, fluid, ford, transmission, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
