Gauge Needles vibrate when truck is turned on. Help! - Ford Truck Enthusiasts Forums
Old 08-18-2007, 01:10 PM
o2civic o2civic is offline
o2civic is starting off with a positive reputation.
2004 F150 Supercrew
44400 miles
So I turned on my truck today and the needles acted as if they were possesed. The went under the "starting points" and vibrated there for about 5 seconds or so... Very strange.
I also have been getting sluggish power from the truck. Mainly between 2000 and 3000 rpms.. Sound like a diesel at times.
Any ideas?
Old 08-18-2007, 01:15 PM
FTE Trigger's Avatar
FTE Trigger FTE Trigger is offline
FTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to all
Which motor do you have?
Old 08-18-2007, 01:17 PM
Quote:
I'm sorry. I meant to put that in..
5.4 V8
Old 08-18-2007, 01:23 PM
Foxxx's Avatar
Foxxx Foxxx is offline
Foxxx has a very good reputation on FTE.Foxxx has a very good reputation on FTE.Foxxx has a very good reputation on FTE.
is the check engine light on? when was the last time the plugs have been changed? what about the oil? sounds like something is either going bad and needs replaced, or you need a tune up...but seriously check your oil cause sounding like a diesel on a mod motor is NOT a good thing...
Old 08-18-2007, 01:37 PM
Quote:
Thank you for the reply.
Plugs are original. I didn't think they needed to be replaced soo soon.
Oil change is due late this month. It was changed last by the dealership.
The only "check engine" light I had was on July 21st. It was P0119. "Engine Coolant Temperature (ECT) Sensor Circuit, Intermittent or Erratic.
I cleared it and it has since not come back.
Fuel Filter was changed between 25k and 35k I can't recall when though.
Old 08-18-2007, 01:38 PM
burner879 burner879 is offline
burner879 is starting off with a positive reputation.
i have heard a few guys on this forum talking about how there 5.4 engines sound like diesels...that is strange when you think about it
Old 08-18-2007, 03:16 PM
last5oh_302's Avatar
last5oh_302 last5oh_302 is offline
last5oh_302 is starting off with a positive reputation.
As far as the jumping needles go, I'd say you're due for a new battery.
Old 08-18-2007, 04:26 PM
Quote:
Really? Is that an indicator? My needles go "under" the starting point.. you know, under 0 miles per hour and under 0 rpms and vibrate there for about 3 - 5 secs. Very wierd..
My ondash voltmeter reads fine when my truck is on. I'll go outside right now and read the battery charge when it's off.
Old 08-18-2007, 04:39 PM
Quote:
Here are my readings using a FLUKE 75 Series Multimeter:
Truck ON: 13.65
Truck OFF; ACC ON
Radio OFF
(Switch OPEN): 12.37
Truck OFF
Door Closed
ALL Dome lights OFF
(Switch CLOSED): 12.62
Do these readings raise any warning flags?
Old 08-18-2007, 05:33 PM
If your battery is on the outs and there's a short of some sort, the needle jumping around like that is a signal. I've had it happen. My tachometer jumped all over the place as did my speedo needles. Changing the battery took care of it.
Try a different battery and see what happens.
Old 08-18-2007, 06:04 PM
screwy's Avatar
screwy screwy is offline
screwy has a good reputation on FTE.screwy has a good reputation on FTE.
The gauges moving and shaking like that was the cluster recalibrating itself. It usually only does this when itís lost its calibration data. If it just happened that one time I wouldnít worry about it too much. If itís doing it a lot then I would say time for a new battery because itís often a sign the battery isnít providing enough power for it during cranking. As far as the sluggish power I would say if you havenít changed your fuel filter recently start there. All your numbers really tell me is your alternator is working.
Old 08-18-2007, 06:10 PM
Quote:
Thanks!
It's really wierd to watch the needles perform this way. Reminds me of a Turbo/ Vac gauge when there is no boost and a vacuum exists..
I checked the "eye" on the battery and I can barely tell a faint green color. Should this "eye" show a vibrant green?
What is the normal "charge" for our batteries?
Old 08-18-2007, 07:41 PM
g-funk g-funk is offline
g-funk is starting off with a positive reputation.
same thing happen to me,went to autozone for a checkup they said i just needed a charge after charging & 5 mins of music while truck was off samething.after visual inspection of the battery ,wich you should do with anything i notice the battery was warped new battery no problem.
Old 08-18-2007, 09:34 PM
hmm.. I might need to add the new battery to the tuneup.
Let's see if that solves the issue. Tomorrow, I am going to change the oil, fuel filter and add an additive to the gas to remove any moisture. I'll also drive over to the auto parts and grab a new battery.
I just finish cleaning my K&N Air Filter. So once I finish those few things tomorrow, I'll be better able to gauge what's going on..
I'll let you know.
Old 08-18-2007, 10:01 PM
screwy's Avatar
Check cables too, could just need a terminal cleaning, Also be careful with the K&N, Iíve heard of people over oiling them and getting their MAF coated causing performance issues.
noise/vibration dallds 1999 to 2016 Super Duty 1 02-27-2016 04:32 PM
02 SD 4x4 Wheel bearing or Needle bearing? Jeepzor 1999 to 2016 Super Duty 3 01-05-2016 06:34 AM
Rear end vibration when acclerating off stop/turn bebeard 1999 to 2016 Super Duty 4 02-09-2014 12:49 PM
Vibration from Front Left side ab1101 1999 to 2016 Super Duty 10 11-14-2010 12:22 AM
Vibrations when hubs are unlocked and I hit a bump -- fine when locked pete2294 Excursion - King of SUVs 5 06-26-2010 12:18 AM
Tags
150, 2004, cluster, f150, gauge, gauges, jumping, needle, needles, shake, shaking, starting, turning, vibrate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
