Gauge Needles vibrate when truck is turned on. Help! - Page 2 - Ford Truck Enthusiasts Forums
Old 08-18-2007, 10:05 PM
o2civic o2civic is offline
o2civic is starting off with a positive reputation.
Quote:
Originally Posted by screwy
Check cables too, could just need a terminal cleaning, Also be careful with the K&N, Iíve heard of people over oiling them and getting their MAF coated causing performance issues.
Terminals are very clean. Almost TOO clean for a 3.5 year old truck.
I know about the K&N. I've been using them for about 7 years. Best filters I have ever used. I have the spray type oil so it's easier to evenly coat the ridges on the filter.
Old 08-19-2007, 09:18 PM
Ok.. So this is what I did:
Changed the Fuel Filter.
Changed the Oil plus Oil Filter (Of course).
Cleaned my K&N Air Filter.
Replaced my stock 4 year old battery w/ a Heavy Duty 850 CCA.
Added an Additive to my Fuel to remove moisture.
Instant change! Start-up is instant.. I've started the truck 5 times and no more shaking needles... So far, the problem was the battery as I was told by many of you. Also, no more diesel sound.. Thanks!
Old 02-12-2014, 04:07 PM
invader1 invader1 is offline
invader1 is starting off with a positive reputation.
My 2008 F150 is doing the same with the gauges. I thought it might be the battery because it turns over slow too. Also worse when its cold. Guess its time for a new battery.
Old 02-13-2014, 05:46 AM
60DRB's Avatar
60DRB 60DRB is offline
60DRB is gaining momentum as a positive member of FTE.60DRB is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by last5oh_302 View Post
As far as the jumping needles go, I'd say you're due for a new battery.
My first thought as well.
My '06 did the same "dash needle dance" and buzzed at the same time, a couple months ago. It still had the original build battery from AUG '05, so it had lasted a good while. I didn't know how slow it was cranking until I installed the new battery. The new battery cranks like the engine is about to jump out of the truck!
noise/vibration dallds 1999 to 2016 Super Duty 1 02-27-2016 04:32 PM
02 SD 4x4 Wheel bearing or Needle bearing? Jeepzor 1999 to 2016 Super Duty 3 01-05-2016 06:34 AM
I need help ! WolfB 1999 to 2016 Super Duty 4 08-12-2014 03:46 PM
Rear end vibration when acclerating off stop/turn bebeard 1999 to 2016 Super Duty 4 02-09-2014 12:49 PM
Overheating toecutter Cooling, Heating, Ventilation & A/C 18 04-16-2003 10:22 AM
Tags
150, 2004, cluster, f150, gauge, gauges, jumping, needle, needles, shake, shaking, starting, turning, vibrate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
