That is pretty much it, but you really need to look at the two different cases.
Case 1 - Cruising down the highway at part throttle. This is where you are interested in MPG and where the higher vacuum number gives better MPG*. The vacuum is just a way to measure the opening of the throttle plates so basically, keeping the throttle light and even gives you the best MPG.
I put the "*" in and the note here is "all else being equal" If you have a dirty air filter or a restriction in the intake that makes you open the throttle more, you may see higher vacuum, but because the throttle is open more, you are dumping in more gas which could hurt MPG.
Case 2 - Wide open acceleration. In this instance, you are concerned with power. All the air that the engine uses has to fit through the air filter and throttle body. Depending on which element is more restrictive, that is what governs the vacuum at WOT. If the most restrictive part does happen to be the air filter and you replace it, you may see the vacuum at WOT decrease slightly which should indicate more power - again, all else being equal.
But, when you go back to highway cruising, the throttle body (and mostly closed throttle plates) is a far greater restriction than the air filter, so your vacuum should be back to normal and along with that, the mileages should be back to normal.
The last thing to consider is the CAI itself. If it really does it's job and picks up colder air, this could cause a little drop in MPG simply because a little more of your gas is now going into just heating the air and because cold air is more dense than hot, it requires more fuel.
On the up side, the difference will probably be very small. At highway speeds, you could literally have hurricane force winds blowing under the hood, so the air temp tends to be pretty equal no matter where you pull it from. Around town, you might see a little gain by pulling air through a CAI.
__________________
Corey
04 Scab 5.4L XLT 4x4
93 XLT 5.8L - RIP
