75 F250 timing
All I have is non-California, from a '79 Motor's truck repair manual.
.044 spark plug gap, 6 degrees BTDC (after removing vacuum advance hose and plugging it) and 650RPMs in drive with an automatic.
I'd think in a truck 390, you could get a few more degrees advance out of it with good gas.
This was copied from an earlier post I made. By the way, a 4 barrel 390 is not suppose to be an option in 1974, but this truck has an 8/74 manufacture date on the door post. The 4V 390 was an option starting in 1975, supposedly. The VIN does have the "M" engine code, which was not for 1974, but did exist in 1975. I think the new model year for cars and trucks in that era was started in September. I believe this was an non California truck.
This is a lot of initial advance. obviously, it your engine knocks at this setting, retard the timing
I have a 1974 F-250, 4v 390 combo in my truck, also. Here is what the sticker on the valve cover says: 390 cid July 1974, Spark plug BRF-42, Gap .032-.036, point gap .017, dwell 24-30 degrees. Timing 16 degrees BTDC, Vacuum hose disconnected and plugged, at idle, 650 rpm in drive, CO 1% max.
__________________
__________________
IDIDieselJohn
08-02-2009 09:34 PM
mjorda2
Electrical Systems/Wiring
12-13-2007 12:00 AM
Imdok
10-11-2007 01:11 PM
b33cpe
02-04-2007 12:45 AM
