legal pulling over 10,000# ?
I pull a trailer for farm use hualing our product. I have heard anything from I am exemt and dont need a special licence, I need non-commercial A restricted, commercial A restricted, and Commercial/non full A. I have gone to MVA many times and have not got the same reply twice.
A neighbor told me that if you pull a pickup and gooseneck you need a full A but if you are running a 10 wheeler with a drop deck you only need A restricted
Im very confused with what I can and cant do no one seems know either. I plan on getting my full A when I turn 21 but that is 3 years away
You must have some awful state rules. In most cases you should be fine a normal class C drivers license is up to 26K GCVW, that leaves a good 18K lbs between the trailer and load weight with the new SD's. Every state could have their own rules that are stricter than that. Also just because the license limit is 26K, if your truck and trailer are rated for less and you are loaded heavier, with the exception of ag, you could get a ticket and be forced to unhook the load. Of course commercial towing is all different and much stricter.
My understanding was you could drive a truck with a GVWR of <26,001# and a trailer up to 10,000# once you go over that you needed an A or B class but asking the idiots at MVA some tell that is true and others say your combo must be under 26000 and others say it does matter what it weighs because you are pulling it with a pick up. There is too much grey area
In IL you need a class A license to pull any trailer over 10k except a trailer with RV plates. I do believe that there are examptions to these laws in the case of farm work, but you have to be an immediate family member of the owner of the farm (father/mother/daughter/son/brother/sister). In any case though I think you have to be over 21 in order to haul a trailer that heavy. Like I said though, this is IL law, your laws may vary.
Edit\
OK I just went and found your state's CDL manual. It appears that you only have to be 18 to get a CDL in Maryland, but you can only drive in your state. It also appears that like in IL you have to have a class A to haul any trailer over 10k except an RV. They do have an exemption for Farmers. Farmers have to get a class A license, but not a commercial endorsement.
So it looks like you have to go to your local DMV and tell them you want a non-commercial Class A license.
Here is a link to the CDL manual.
http://www.marylandmva.com/Resources/DL-151.pdf
Edit\
I live in Nevada and even DMV seems confused over what you can tow..I got a "j" endorsement for towing over 10,000 pounnds (max gross is 26,000) and an "R" endorsement for towing a combination up to 70 feet as I tow a quad trailer behind my fifth wheel. But I wasn't charged for the two endorsements I only had to take a test.
A friend told me you couldn't tow a triple through Arizona on my way to Utah and I almost canceled a two week trip. Luckly for me I decided to check on line with Arizona DMV and he was wrong. The trip went great althrough I got a lot of looks towing that 64 feet rig. Several police I saw never gave me a second look. Check with DMV for each state don't just go by what people tell you.
Randy
Randy
http://www.marylandmva.com/Resources/trucker.pdf
Originally Posted by jake00
page 14/96 says youre exempt. might wanna print it out and keep a copy with you.
You are not required to have a CDL to drive a vehicle that has been granted a waiver. You must however, have a Maryland non-commercial driver's license of the appropriate class to operate a vehicle which has been waived.
The following vehicles have been waived from CDL requirements in Maryland and thus considered non-commercial for the purposes of CDL:
a. A vehicle controlled and operated by a farmer:
<DIR><DIR>• used to transport agricultural products, farm machinery, or farm supplies to or from a farm;
• not used in the operations of a common or contract motor carrier; and
• used within 150 miles of the person's farm.
</DIR></DIR>
