How Do I Identify A Stock Axle?
OK, this may be the start of a lot of harassment, but I thought I had a dropped axle and now I am not so sure. The leafs are definately stock is there anyway to identify a stock axle? After searching through many galleries my truck doesn't look low enough to be an aftermarket axle. Any help is great.
I just removed my stock axle and replaced it with a drop axle. The two axles look identical and by eyeball, you can't see the difference if ever slight. The best way is to measure a stock axle and then measure yours from the straight axle to the top of the spindle. I sure noticed a difference when I installed it though.
Thanks for the Post
Kent,
Thanks for hooking up the picture. You gotta be smarter than the machine you are working with. I like the straight axle I would just like to be a little lower. 2 or so inches. I am finishing up my 4 bar in the rear and the wheels are turning (in my head at least).
I know mine's stock, and I can measure it if need be. Just lemme know.
