Perf Specs on 1999 Ford V10 6.8L - Ford Truck Enthusiasts Forums
Old 10-16-2002, 10:15 AM
stevem777 stevem777 is offline
stevem777 is starting off with a positive reputation.
Greetings,
I am looking for horsepower and torque specs on the 1999 Ford V10 6.8L engine used in the Super Duty E Series on motorhome chassis. The manufacture date on the particular chassis I'm looking at is 5/5/99. Thanks.
Steve
Old 10-17-2002, 01:47 PM
ken04's Avatar
ken04 ken04 is offline
ken04 is starting off with a positive reputation.
>Greetings,
>Steve
265 HP and 405 ft lbs of torque. They were @this in 98 and 99 and part of 2000 I believe. The pick-ups had 10 more HP in those years because of the aircleaner system, check it out sometime, it's amazing any air gets through there. Ken. 98 E-350 XLT V-10 ClubWagon
Old 10-17-2002, 10:51 PM
Godzilla250v10 Godzilla250v10 is offline
Godzilla250v10 is starting off with a positive reputation.
transmission swap on 1999 e350 6.8l v10 frustratedvanowner New Member Introductions 2 02-14-2017 01:29 PM
bolt torque specs Grimblore Modular V10 (6.8l) 2 01-22-2016 09:00 AM
find the ECM 6.8 1999 motor home f53 chassis perandall2000 Modular V10 (6.8l) 8 11-29-2012 12:23 PM
V8 vs V10 Compression Ratio bterry Modular V10 (6.8l) 12 02-01-2006 07:10 PM
engine stalls out on hills in hot weather royalv10 1999 to 2016 Super Duty 11 08-09-2003 12:14 AM
Tags
1960s, 1999, 2002, 68l, 98, 99, air, cleaner, engine, ford, motorhome, mustang, power, specs, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
