DP tuner questions
DP tuner questions
im thinkin of getting one of these for my truck... i have after market intake is air raid and exhaust is 5" strait piped so i dont think im gonna have any problems with breathing, my question is guages for boost psi, egt's and stuff or is it safe to run it with just what i have now? if this helps the truck has 155k miles 99 f350 PSD
Anything above safe 80hp tune guages are a must! EGT anyway, This is the way you have to look at it, would I rather spend 200 bucks now to monitor EGT or spend several thousand latter because you THOUGHT it was safe! The choice is yours. I ran an 80hp superchip for 6 yrs with no Issues, once I put an EGT guage in and ran the truck (hard) I found out the my EGTs offten hit 1200+ deg, any higher than 1250-1300 for more than a few seconds and you start doing damage to the turbo! I was lucky I never damaged anything, Ive herd some of the tunning companies say that you can use 60hp tune safely!
Rich
Rich
Rich
Rich
I'm not so worried about the turbo as I am of the pistons. Too hot and they get soft and blow out.
Originally Posted by RogueSpear2023
Sorry to hijack, but does the DP tuner change or stiffen you shifts or does it only adjust the engine parameters?
Originally Posted by HKusp
BTS VB. My tranny is doing fine so far. It just turned 70k this weekend so I hope to have many more enjoyable miles out of it before taking the big plunge and getting the whole BTS tranny.
The EGT (exhaust gas temperature) gauge is technically called a PYROmeter. WOT= Wide Open Throttle, however that's inaccurate for a diesel as they do not have throttles. I prefer to use the term Full Fuel.
15/92, high exhaust temperatures do not hurt the turbo. At least 1300* wont. It's the aluminum pistons that get abused during high temp operations, as pure aluminum melts at 1228*.
