Any of you guys run seafoam?
I've used it before but not on this truck. Just thought it wouldn't hurt, I'm sure there's plenty of carbon in that motor. Was just going to run it through the brake booster line.
Just wondering if anybody has used it without complications?
I also read that if you haven't done it before it might be a good idea to swap out the plugs afterwards, any truth to that?
Thanks,
Mike
Thanks,
Mike
I've ran it in a few engines including my boat with no problems. I usually just trickle it in the carb for about a minute and increase until it floods, let it set for about five minutes then fire it up and fog up the subdivision. As far as the plugs go, I left mine as they weren't that old.
Used seafoam on some old rigs- some in the tank, some in the crankcase, and then down the carb 'til she floods out. Let 'er sit 'bout 10 minutes, then proceed to kill off any mosquito in a 5 block radius. Newer rig I wouldn't do this to it- the motorvac FI/induction cleaning is the way to go (God knows what seaform would do to the O2 sensors and ECU. Seizure time,anyone?)
Originally Posted by Danger_Dave
what is seafoam? i have no idea what is going on here
http://www.seafoamsales.com/motorTuneUpConsumer.htm
Originally Posted by azfordf100man
Well, I just put it in yesterday and i was surprised to see that there wasn't nearly as much smoke as i thought there would be?
Over on the Rover forums they talk about needing it done many times a year.
I have seen many of these aluminum motors that owners have sucked it into the intake then added to the crank case as a was told "a must do item". A 50,000 mile motor looked like 250,000 miles in bore wear, rods and mains down into the brass besides muffler shops like this product as they get to replace the coated and destroyed catalytic converters. They claim no damage, tell it to a $1,447 bill for a BMW owner that had a catalytic converter replaced after the use of said product.
A properly tuned, driven and maintained motor does not need this. JMO's from what I have seen at the Rover dealer and local muffler shop hang outs.
I know i;ll get hammered because it says on the bottle no harm, I also believe in Santa.
I've used it with no ill effects.
I used it on my bronco, and it lowered the RPMs, and gave better mileage(2 or so, but it wasn't to well maintained by the previous owner).
I've used it in newer trucks and nothing wrong with the cats.
Earlier someone said to put a whole can. I would not do this. I talked to someone that put a whole can in at one time and seized his motor. Half a can in the intake, and the other half in the gas tank.
