Drivers side cubby pocket (mini-glove box) missing in XLT
Hi all, I just bought a 05 XLT and I noticed that it doesnt have the little cubby pocket that is underneath where the Tow Command and upfitter switches are.
It sort of looks like a mini-glovebox for the driver. I would like to put that in my truck, which has the grey interior. Does anyone know the part numbers, or where I can buy that center piece from?
Below are some pics to show what i mean.
Picture of a truck that HAS the cubby below the upfitters:
Picture of MY truck with no Cubby:
I may be able to get you some numbers in the morning...............I just ordered a replacement for mine, it broke
Mike11C, it is just like he said, a really small version of a glovebox.
On edit -- After reviewing both pictures, it looks like the one on the bottom truck may have been purposely ommitted, and looks like it is even a different profile at the bottom, almost concave where as the uipper one is perfectly straight along the bottom. I am thinking maybe omitted and clearanced purposely to allow 100% uninhibited movement of the floor shifter?!? Thoughts anyone?
Thanks for the help miker67, I think it will be two part numbers... one for the actual dash panel and one for the little glove box. If you can get those part numbers, I owe you a few beers!
Mike11C, when i stated "cubby" i meant the little glove box beneath where the upfitters and tow command is. Alot of folks refer to the "cubby" as the little pocket next to the tow command (as seen in the second pic),
I am actually wanting to get the whole lower dash assembly that would have the mini glovebox as well as the dash panel.
Originally Posted by schmidt64
Yes, trucks with the manual transfer case do not get the driver side glove box
I don't mean to hijack the thread, but I noticed in the pic of your truck you have the ability to turn the passenger side airbag off. I don't have that option in mine. Why? Is it because I have the Crew Cab?
Originally Posted by nut1605
What he said. I have the manual 4x4 and because of the floor shifter, they don't put the drivers side glove box in. I was disappointed when I got my truck and saw that too. Although it is nice to see another 6 speed around here
The passenger air bag disable switch is only available on regular cab and super cab models. Crew Cabs don't have that option. (Too bad, as it would be better when hunting and off road - at least for the passenger)
I took a closer look this morning on my way to work, and I noticed that the glove box would more than likely hit the 6 speed stick when it is opened. Theres plenty of clearance for the transfer case lever, jut not the actual shifter lever.
Hey Nut, did it take you a while to get used to shifting your 6 speed? I have had the truck almost a week now, and I am still getting used to the gearbox Shifts totally different than any other standard tranny Ive ever drove.
The drivers side glove box is not available on trucks that have manual 4x4 or manual transmissions because it will hit on the levers.
The airbag shut off switch is only put in on regular cab and super cab models since a child seat will most likely be put in the front passenger seat, so they have to be able to shut off the airbag. Our trucks do not have the weight sensor that shuts off the airbag if the passenger seat sees less than a certain weight, like some cars do. However, if you really want the air bag shut off switch in your crew cab it can be added. The harness is hiding behind the dash, you just need to order it and plug it in. I'm not sure if the dealer has to change the PCM programming to enable it or not, does anyone else know?
Originally Posted by WildWildWest
The driver's side glove box is not available with manual transmission - can't get it. Only an option with automatics XLT trim and up....
I do have a manual transfer case (as was previously mentioned) so that must be why I do not have it.
Originally Posted by redford
I have an '07 XLT with an automatic and do not have the driver's side glove box, so this statement isn't true.
As far as the airbag switch, I figured it was only available in Reg. Cabs and Super Cabs. I don't necessarily want it, I was just curious why mine didn't have it. Thanks guys!
SoCalAngler
1999 to 2016 Super Duty
05-31-2017 11:45 AM
