Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-14-2007, 05:07 PM
351slug 351slug is offline
Garage is empty, add now
351slug is gaining momentum as a positive member of FTE.
TPS replacement
It looks like the throttle body needs to come off to change it. Can I reuse the TB gasket? What else do I need to know. I am getting a code for it and the MAP sensor. Runs ok but cuts out during heavy throttle and have to let off to run smooth again.
  #2 (permalink)
Old 08-14-2007, 05:20 PM
mhg mhg is offline
mhg is starting off with a positive reputation.
Test it first
www.fordfuelinjection.com will show you the procedure
__________________
2003 bull 3.0 24v stock
1996 E-350 351
  #3 (permalink)
Old 08-14-2007, 05:46 PM
Moore558's Avatar
Moore558 Moore558 is offline
Moore558 is starting off with a positive reputation.
What are the code numbers your getting?
My F150 was doing the same thing when I got it. What was happening was the TPS voltage was dropping to 0 under hard throttle and it shouldn't have been doing that. I replaced the TPS and also found out the pigtail from the ecu harness had gone bad and it was the primary reason that my TPS failed. I replaced both the TPS and pigtail and haven't had any problems afterwards.
Yes the Throttle Body does have to come off, but a new TB gasket is under $5 so just buy a new one to be safe.
__________________
02 F150 2WD 4.2L V6 M5R2 named "Spaz" thanks to the psycho instrument cluster.
Farewell Baby. You will be forever missed. 03-29-96 to 07-16-2008
http://i3.photobucket.com/albums/y71...4/a5cb37cd.jpg
Last edited by Moore558; 08-14-2007 at 05:47 PM. Reason: Need to restate question.
  #4 (permalink)
Old 08-14-2007, 05:55 PM
TheRoadVirus TheRoadVirus is offline
TheRoadVirus is starting off with a positive reputation.
I just replaced mine the other day and I had a new gasket thinking I would need it for sure and it ended up being fine and dandy. In fact it was in such good shape even If I did replace it there would be no scraping necessary.
  #5 (permalink)
Old 08-14-2007, 08:41 PM
mrl390's Avatar
mrl390 mrl390 is offline
mrl390 is starting off with a positive reputation.
I reused my gasket and it worked out fine but it wouldnt hurt to replace it. Be sure to have something ready to plug the coolant lines or you will be sopping up alot of antifreeze. Soak the bolts for the throttle body with pb blaster first. Also, to keep from stripping the TPS screws, give them a little turn tight to break them loose then turn them loose and out. Be careful with the cables on the top of the TB so that you dont break anything when you take them off. And remember where and how everything goes so it goes back together easier.
__________________
Goodbye old friend
-MATT
  #6 (permalink)
Old 08-14-2007, 11:48 PM
Overkill-F1's Avatar
Overkill-F1 Overkill-F1 is offline
Overkill-F1 is starting off with a positive reputation.
I didn't disconnect the coolant lines when I re & re'd my TPS, they were long enough to leave them connected and still do the replacement. I used the old gasket to trace and cut out a new one.
...Terry '90 F150 302
__________________
It is a simple task to make things complex,
but a complex task to make them simple.
  #7 (permalink)
Old 08-15-2007, 04:48 AM
OK thanks. I am getting codes 121,122,128. I had a coolant leak on bottom line to TB for about a year, could have got inside TPS.?
  #8 (permalink)
Old 08-15-2007, 06:13 AM
mrl390's Avatar
I had to disconnect mine only because the screws were so tight on the TPS that I had to push hard against them with the screwdriver to keep them from stripping when I turned them. I could have got them with a phillips head bit in a 1/4 inch socket without removing the coolant lines if the stupid screws would have came out easier.
__________________
Goodbye old friend
-MATT
Tags
1987, 1994, 1996, 2004, 351, f150, ford, position, problems, removing, replace, replacement, sensor, throttle, tps, trcck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
