Brake pedal sticks and will not return all the way. - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 08-13-2007, 11:41 PM
backyard_costomizer backyard_costomizer is offline
backyard_costomizer is starting off with a positive reputation.
I have a 86 BroncoII. My brake pedal sticks and will not return all the way. I've replaced the pads and checked the shoes, and recompressed the pistons inside the calapers. I'm thinking that it might be the master cyclender, but is there a way to be sure that is the problem??? please help.
Old 08-14-2007, 06:33 PM
my72ford my72ford is offline
my72ford is starting off with a positive reputation.
sounds like it could be the master cylinder..have you checked to make sure the fluid is full? does the pedal come back up if you pull it up?
Old 08-14-2007, 09:51 PM
yeah i think it is too, but it might also be the brake booster. i need to cheack to see if its pulling a vacume. yeah the master cyclinder does have fluid in it, and i re-blead the brakes today. im going hopefuly tomorrow to get a new master cyclinder. ill keep you posted on my progress. thanks. if you have anymore ideas please feel free to post them. and the pedal does return if i pull up on it.
Old 08-15-2007, 07:03 AM
kernel-panic's Avatar
kernel-panic kernel-panic is offline
kernel-panic is starting off with a positive reputation.
Sounds like the master cylinder (and it's probably allowing air back into the system). I would also check the booster to make sure it's okay as well, but even if it was toast, I don't think it would cause this problem.
Old 08-15-2007, 08:32 AM
FordCwazyGuy FordCwazyGuy is offline
FordCwazyGuy is starting off with a positive reputation.
My 86 did EXACTLY the same thing after i got it back on the road,but mine sat for a while,it was the brake booster in my case,i replaced the master cyl and no changes,i had a scrap ranger sitting here and swapped that one out with it,solved the problem in my case.
My son has an 87 B2 all cut up and just used for the woods,his brake booster was leaking vaccumm real bad,he took my old one from my 86 and for the heck of it sprayed WD40 in the interior side of the booster and worked it loose,he's still using it in his with no problems but i wouldnt recommend that for a daily driver thinking the WD40 may hurt the seal or something in there.
Old 08-15-2007, 11:30 PM
well i did cheack the booster today, it is fine. Im going tomorrow morning to get a new master cyclender. if that doesnt fix the problem, then it has to be the calipers. one of the pistons could be defective. but who knows. thanks for all the help on this problem. i did find a nother one today as well though. i just noticed that i have a slight miss in the engine. what should i do to try to fix this? there are new plugs and wires already in it. and i ran a can of restore through it today. where should i look next?
Old 08-16-2007, 09:31 AM
Check the cap, rotor, base timing, vacuum lines, distributor pickup, tfi module, fuel filters, fuel injectors, Idle air control/Throttle body (cleanliness), MAP Sensor, EGR, O2 sensor. Pretty much in that order.
Old 08-16-2007, 01:37 PM
new cap and rotor. the base timing was set last week. all new vacume lines. fuel filters and injector are new as well. the 86 doesnt have a map sensor. and EGR checked out last night.
Old 08-16-2007, 04:23 PM
mblayton's Avatar
mblayton mblayton is offline
mblayton is starting off with a positive reputation.
Usually its the booster that will cause this problem, had it happen on my '76 had to drive with two feet one to press the pedal and the other to pull the pedal back up once you resumed driving
Old 08-16-2007, 05:44 PM
well it is the booster. i had to order one. so i will have it fixed soon. and to fix my last repliy, it has a MAP but not an EGR. the MAP check out.
Old 08-19-2007, 06:06 PM
Uh. Okay. My understanding was that the '86 & '87 (but not the '88) 2.9 FI 1st Gen Bronco IIs had an EGR valve and that all BIIs had a MAP sensor. Weird. Someone please correct me if I am wrong!
Old 08-23-2007, 08:03 AM
on 83-87, i beleave its called a pivit valve, but it does the same damn thing as an EGR. i might have the name wrong.
Brake Pedal not Returning hankviii 1973 - 1979 F-100 & Larger F-Series Trucks 8 08-04-2015 10:58 AM
Slow Brake Pedal Return joefordtruckf250 1961 - 1966 F-100 & Larger F-Series Trucks 3 11-11-2014 05:52 AM
accelerator sticking myutesux Ford Inline Six, 200, 250, 4.9L / 300 3 09-08-2014 12:44 PM
Brake Pedal Issues JRB65 1973 - 1979 F-100 & Larger F-Series Trucks 37 08-08-2013 03:46 AM
1977 F250 Clutch Pedal sporttaz 1973 - 1979 F-100 & Larger F-Series Trucks 7 10-25-2011 09:07 PM
Tags
2005, back, brake, break, bronco, clutch, ford, half, pedal, pedle, released, return, slow, sticking, sticks, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
