steering column
They are replaceable, almost press out by hand and are of the tin can type that are cheap to replace. Seems the botton one fails first.
Check the alignment of the column to steering box and correct if needed.
I had a couple spare columns that I removed the bearings, kept the smooth turning ones, flushed clean then repacked with grease.
Call me cheap but they are holding up going over 600K miles.
Originally Posted by R. Tovar
column on my truck got rough to turn. got a new rag joint in it. are the bearings in there rebuildable, or do i need another column.
2-B1AZ-3518-A .. Steering Column Bearing Plastic Sleeve.
1965/72: One bearing and sleeve fits to the upper steering column flange, the other pair at the bottom of the column.
These parts are easy to find, as they fit Ford passenger cars, including 1965/68 Mustangs, 1963/65 Falcons, etc.
1964/72 F100/350 2WD's use the same cab mounts upper and lower, front and rear. These mounts are available from FTE sponsors like Mac's, Blue Oval Truck Parts and Auto-Krafters. The links are listed above, at the top of the page.
on my 71 i had a few years back i snapped something inside my column from trying to go from reverse to park. it seems they like to go to neutral first and then toss it up into park. my buddy also had that happen to him with his 74, so it seems the steering columns in these trucks break from time to time. it was something deep inside it that i couldnt take apart after yanking the sucker out of the truck. the shift lever would move and the linkage wouldnt. oh well just figured i'd share that little bit of info.
on
Originally Posted by JimAllen
This is a little off subject, will a late model F150 column fit a 1968 truck, i want to put a AOD in and would like to use a column shift
Look at the connection to the gear box and where its mounted to the dash. If those are the same it can be done. I read an article where someone used a newer tilt column. I do not remember the year he used. But he had to trace out the turn signal and horn. The newer column had the HAZ switch on the column.
Under 'public profile' listed vehicle as 70 pickup; if so, posting couple links, if an earlier model appears from the article in the 1st link the parts needed for the rebuild are same; need to do the research??
The Ford 3-Speed Manual-Shift Column Explored - FORDification.com
Ford Truck Technical Drawings and Schematics - Section C - Steering Systems and Related Components
In re: to the column to dash mount for later model columns seem to recall member mentioning swapping brackets since secured by tack welds?
