ABS code C1206-2003 F150 SuperCrew - Ford Truck Enthusiasts Forums
Old 08-13-2007, 12:57 AM
rmccann4 rmccann4 is offline
rmccann4 is starting off with a positive reputation.
Hi Folks,
My amber ABS dash light in my 2003 F150 came on the other day. I changed out the rear pumpkin sensor, ohmed the front wheel sensors (they were within specs posted in FTE forum) and changed out the master cylinder pressure switch under the hood (my left/rear bulb was burnt out around the same time the ABS light came on). After doing all this the light remains....so I had the ABS code read and mechanic advises code C1206 was present. He recommended replacing the "dump valve on the frame rail". He also advised this is a very expensive fix so I might just want to live with the light being on all the time. Has anyone had this happen to their trusty Ford? Is this a expensive part like my mechanic advises? What should my next steps be to get rid of the ABS light and get my ABS system working properly?
Thanks in advance!
Ron
2003 F150 SuperCrew 4X4
4.6L V8 , 285/75/16 tires , 127K miles
Old 08-13-2007, 09:49 AM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
The problem is more likely the ABS module but first make sure all the fuses under the hood and dash are good, especially fuse 102 under the hood.
Old 08-13-2007, 10:27 PM
tpgeneral tpgeneral is offline
tpgeneral is starting off with a positive reputation.
If you start your engine with presure on the brake and don't let off does the lamp stay off?
Old 08-14-2007, 12:26 AM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
C1206 is a an inlet valve rear coil failure.
There is no cheap easy way around fixing it.
Old 08-14-2007, 12:14 PM
Thanks for the quick replies racerguy,tpgeneral and bluegrass 7! You folks are great and have awesome input!
I checked all the fuses inside cab and under hood...all fuses are in good working order for now! I held the brake pedal down while I started the truck and the ABS light on dash was not there until I let off the brake pedal and the ABS light returned. It seems like holding the brake pedal while starting the engine would just prevent the ABS self check test from running...not sure though...just and educated quess.
I quess I will start looking for an ABS module and see what they cost.
Thanks again!
Ron
Old 08-29-2015, 02:22 PM
Hello folks,
I finally revisited my ABS problems on my 2003 F-150 SuperCrew XLT 4x4...I bought an ABS Module from Rock Auto online($350) and swapped it out with my old factory unit.....(I ran the truck for about 7-8 years with the ABS fault light on)...after I replaced the module a few more codes popped up...C1155 left front wheel speed sensor circuit failure, C1145 right front wheel speed sensor failure, C1230 rear center input circuit failure, C1148 right front wheel speed sensor coherency fault and C1095 pump motor circuit failure......After seeing these codes I started with replacing the rear sensor on the differential ($20) and then re-scanned with my scan tool...then had code C1145 right front wheel speed sensor failure....then I replaced the right front speed sensor and that cleared my ABS light from the instrument cluster....I'm finally relieved to have this problem fixed....it just took a little time, money and ford truck enthusiast forum help to complete! Thanks everybody!
ABS Control Module Inspection And Testing Longshot 1997 - 2003 F150 4 09-14-2016 08:08 PM
ABS light on '96 E350 ogarcia434 1968-2013 Full Size Vans 2 05-22-2016 09:33 AM
ABS light on constant after axle swap Taylortd Excursion - King of SUVs 0 10-13-2015 10:35 PM
2003 Superduty ABS light narrowfarm 1999 to 2016 Super Duty 5 03-25-2015 02:00 PM
Brake Senors 93aerostar Aerostar 4 12-10-2003 07:51 PM
Tags
150, 2001, 2002, 2003f150, abs, c1206, code, crew, f150, ford, light, master, stays, super, supercrew, switch, system, truck, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
