95 -98 Explorer rear end questions - Ford Truck Enthusiasts Forums
Old 08-13-2007, 12:44 AM
blue57's Avatar
blue57 blue57 is offline
blue57 is starting off with a positive reputation.
In another forum there was mention of the 95 - 98 Explorer rear ends being an 8.8 posi, with 3.73 (possible) gearing, with disk brakes. I'm curious as to the stated width of 59".
Would that be 59" from wheel mounting surface (WMS) to WMS?
What would the leaf spring mounts (center to center) measurement be.
Those have a standard 5 X 4.5" bolt pattern don't they?
Are they ALL posi?
Old 08-13-2007, 10:02 AM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
not all posi.
59" is probably from end to end.
98 Explorer Axle Swap into 93 Lightning Roadbird Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 2 11-05-2014 09:29 PM
05+ different rear end from older gens? Greg5OH 1999 to 2016 Super Duty 0 07-05-2014 12:42 AM
76 highboy powerstroke conversion Brycemunro 1973 - 1979 F-100 & Larger F-Series Trucks 15 01-08-2014 12:10 PM
dana 35 front axle brake mods? havi 1966 - 1977 Early Broncos 12 09-23-2012 12:32 AM
8.8 4.10 gears? 98F150LLC 1987 - 1996 F150 & Larger F-Series Trucks 19 03-26-2007 07:10 PM
Tags
95, end, explorer, ford, posi, rear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
