no signal or brake lights-intermittently 2000 f150 4x4 - Ford Truck Enthusiasts Forums
Old 08-12-2007, 05:59 PM
mr.big mr.big is offline
mr.big is starting off with a positive reputation.
Cool no signal or brake lights-intermittently 2000 f150 4x4
hi everyone-im a licensed g.m. tech and have worked on all models of cars througnout my career.i have had the truck for the last 5 years no major issues at all.year and a half ago 20 amp break fuse popped in wet conditions. Traced it back to a faulty Multi function switch. replaced with used switch no problems until june 07. Same fuse popped, installed new fuse, pops immediately, installed new multi function switch, still no brake or tail lights. Happened again in wet contditions, never happens when vehicle is in use, only after being parked. Installed short locater. Could not see any chaffed wired, no corrosion in any plugs on frame, checked trailer wiring (does not pull trailer). Installed new 20 amp fuse. Was ok until today. Have I over looked anything? Anyone experience this? Checked complete wiring harness from trailer plug to UHFB. Ford couldn't help, said nothing wrong. Slight moisture here Thursday, possibly contributing to condition. Working fine now, please, please please any ideas would help me at all. Truck in garage only 80K.
Signed frustrated
Old 08-12-2007, 11:14 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Welcome to the forum....and the dark side
When you replaced the multifunction switch did you take a look at the connectors on it? The wires pull out of the hardshells quite regularly, especially if it has tilt.
These trucks do suffer sometimes from water getting into the under dash fuse box and GEM (Generic Electronic Module) which is attached to the back of the fuse box. Usually the water gets in there from a leaking windshield. Your symptoms aren't common for this problem but anything is possible. The common symptoms for that problem are the heater won't turn off with the key out and things like that.
You said you checked the trailer wiring. Have you tried removing the trailer harness from the system and see if that changes anything? I've been fooled by bad trailer harnesses and plugs before.
Old 08-26-2007, 09:44 PM
Smile
Thanks Dave For The Advice- I Believe The Problem Was Contacts Sticking In My Turn Signal /hazard Flasher. Replaced It - So Far So Good . Ive Neber Really Heard Of This For A Blowing Fuse Concern But Like You Said Anything Is Possible. Sorry This Is So Long In Returning I Went Down To Montans For A Small Vacation - Truck Ran Great All The Way.mobil One Oil For 19.99 For Five Quarts . Cdn Equivalent Probably 44+ Dollars. Thanks Again . If You Ever Need G.m. Help I'm Here. Murray A.k.a Mr. Big !
Old 01-24-2010, 10:07 AM
colinc2010 colinc2010 is offline
colinc2010 is starting off with a positive reputation.
ARE YOU TALKING ABOUT THE CONTACTS IN THE FUSE BOX OR IN THE COLUMN?
1990 F250 Brake Light problem. Strychnine08 1987 - 1996 F150 & Larger F-Series Trucks 37 12-02-2016 05:21 PM
New guy ! no turn signals Casper99 1997-2006 Expedition & Navigator 46 11-09-2016 06:58 PM
F53 brake light and hazard flashers failure meporsche 1999 to 2016 Super Duty 5 04-03-2016 04:05 PM
No turn signals or hazard lights carlsson 1999 to 2016 Super Duty 1 07-09-2015 05:06 PM
Brake light fuse popping. I'm stuck here. fabiodriven 1999 to 2016 Super Duty 4 04-26-2015 03:07 AM
Tags
2000, brake, f150, ford, function, fuse, heritage, light, lights, location, multi, signals, switch, truck, turn, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
