98 Explorer RemotesKeyless Entry Poor Range
Old 08-11-2007, 09:04 PM
petdoc87's Avatar
petdoc87
petdoc87 is offline
Hi to all. I have a 98 Explorer with Remote keyless entry. The keypad keyless works fine the remote key fob does not. I found the module (back left forward of the jack) and when the fob is pointed at this area it works. Any distance from the truck and the fob stops working. I changed the batteries (twice) in the fob, thinking low batteries would decrease the distance. This did not help. So I am thinking there must be an antenna somewhere that is disconnected. There is no obvious antenna exiting from the module. So my question is.
1) Is there an antenna for the remote keyless entry. If so where is it and how can I trouble shoot it?
2) Any other ideas??
Thanks to all for your help.
JRM
Old 08-12-2007, 10:18 AM
njf207's Avatar
njf207
njf207 is offline
I do not think there is an antenna. One thing that will really kill your signal is other remotes on your key chain. If there are other remotes to close to the remote that you are tying to use they will create interferance. Other than that I woul replace the remote.
Old 08-12-2007, 10:22 AM
Backin72's Avatar
Backin72
Backin72 is offline
Has the remote ever gotten wet? A little corrosion inside the remote will affect it's range, amongst other things.
Old 08-12-2007, 06:00 PM
petdoc87's Avatar
petdoc87
petdoc87 is offline
Very Interesting, I have both remotes together. In the past they where seperate so I'll try that. No the remotes have never gotten wet. I will let you know. Thanks.
Old 08-12-2007, 06:53 PM
petdoc87's Avatar
petdoc87
petdoc87 is offline
Ok so I couldn't resist. Separated the remotes and gave it a shot. Disappointingly no change. The remote works if it is near/ pointed at the left quarter panel (the module is visable on the other side. Anybody got another idea?? Thanks again for the help.
JRM
Old 08-12-2007, 08:49 PM
oojbearoo's Avatar
oojbearoo
oojbearoo is offline
i was having problems with my 96 explorer remote with no range I came across a how to video to boost ur remote basically if you open your remote there is a dime sized silver circle thats ur remote antenna if you solder onto it a piece of wire it boosts your signal make sure the other wire end is taped and the cover fits back on the same way (have to move the wire with bends) i gained about 20 foot from it not as good as the 50+ the video says you will get but ill take it GL =D
Old 08-13-2007, 07:45 PM
Nasty350LT1's Avatar
Nasty350LT1
Nasty350LT1 is offline
"One thing that will really kill your signal is other remotes on your key chain"
What have you been smoking ?
That is the funniest thing I have ever heard. :lol:
73Custom
2009 - 2014 F150
10-08-2022 03:00 PM
zjohnson3
2009 - 2014 F150
11-03-2015 05:23 PM
abovetec
04-23-2014 05:32 PM
JB17
1999 to 2016 Super Duty
17
12-22-2013 02:54 PM
fordguy2236
1997 - 2003 F150
07-13-2013 09:49 PM
Quick Reply: 98 Explorer RemotesKeyless Entry Poor Range
