Carb Rebuild
Originally Posted by Big Blue 87
Are all the carbs on the 460's from the 80's box trucks and pick-ups the same? I know it is a factory carb. I would like to get a rebuild kit for it. Also are they all 600 CFM? Thanks
Originally Posted by 69-highboy
You are better off replacing it with an Edelbrock/Carter than fixing that old Holly. If it is a high-mileage unit, the throttle shaft is probably worn, and well, that's a vacuum leak that can't be fixed.
ian's truck
02-02-2013 01:53 PM
HT32BSX115
08-07-2005 07:56 PM
ken's1971
03-25-2005 04:40 AM
